View Poll Results: Which date is best for a spring dyno at AFI
April 11
5.00%
April 18
10.00%
May 9
20.00%
May 23
13
65.00%
Voters: 20. You may not vote on this poll
Spring Dyno at AFI Edmonton
Old Apr 18, 2009 | 08:25 PM
  #46
morkable's Avatar
Im still in, but it will be with the chevy
Old Apr 18, 2009 | 11:42 PM
  #47
Tate's Avatar
Tentatively, I am still in. Should be working in Ft. Sask by then, so should work well.
Might even have some new fancy DV's to play with by then too.
Old Apr 19, 2009 | 09:17 AM
  #48
Mike Holmen's Avatar
The Guru
It was pretty quiet here lately, so I just had to kick the tin can.
Tate, you gonna put the DV into the 12V or 24V? I think you should put in the DDP competion sticks and DV, as you need alot more fuel. You might need to adjust the wastegate. I just hooked-up my methanol kit yesterday, I'm a believer so far. I'm just using a little 325ml nozzle. I picked up 5 to 7psi of boost and drop egt's by 200 deg's. My max egt's are around 1200 deg's, at 40-45 psi. I'm pumped. Might try more methanol, later...
Old Apr 20, 2009 | 11:06 AM
  #49
kennyblatz's Avatar
i got a guy interested in my turbo might be spinning a gt4094r by dyno day. see if i can't break 500hp
Old Apr 20, 2009 | 12:28 PM
  #50
Diesel Dave2's Avatar
Pickin on the wrong admin...
I left Martin a message to confirm the May 23 date...Once I get his call I will post, to tell you guys its a go...
Old Apr 20, 2009 | 01:58 PM
  #51
I talked to Martin....We need a start time for may 23???I was thinking about 9:00 or 9:30?What do you think?
Old Apr 20, 2009 | 02:12 PM
  #52
The Guru
I'm good with that time but we would have to gather at the Esso just north of Airdrie at around 6:00-6:15am. It would be good to see everyone again.
Old Apr 20, 2009 | 03:13 PM
  #53
Also Martin mentioned that if we start later,he will also keep his shop open later...
Old Apr 20, 2009 | 06:58 PM
  #54
ccmckee's Avatar
That's a good time, gives us southerners extra time to get there.
Old Apr 20, 2009 | 07:11 PM
  #55
1-5-3-6-2-4's Avatar
ok so far so good, I'm still in. Ill hope to drag out a duramax and another 2nd gen dodge.
not looking forward to pulling my duals though/.
Old Apr 20, 2009 | 07:14 PM
  #56
morkable's Avatar
Not that it matters to me, but knowing Martin, 10 is best, he is not the best morning person. And when he says he will stay open later, he means it.. so we will definately have lots of chat time and dyno time.
Looking forward to seeing you all
Kevin
Old Apr 20, 2009 | 08:00 PM
  #57
Hey Luke...When I dyno on Martins machine,I didn't have to take the duallies off..
Old Apr 20, 2009 | 08:01 PM
  #58
I like the idea of 10:00....
Old Apr 20, 2009 | 09:22 PM
  #59
dodgediesel's Avatar
Anyone going to the races on May 2nd??? Going to go hang with the "Orange Truck".......
Old Apr 20, 2009 | 10:24 PM
  #60
I remember. but I'm about 8' 2" wide now which is I think about 10" wider than it used to be with the stock tires. 5" per side at least.
