Since the site won't let me search......
Old Feb 20, 2011 | 03:16 PM
Festus's Avatar
What is the width of a stock rim on a 2007 MegaCab? I think I may have found a really expensive 35" tall tire I might take a look at. 35x12.5R17 is the largest tire I can fit even with a levelling kit - correct??
Old Feb 20, 2011 | 04:25 PM
madhat's Avatar
Administrator/Jarhead
A 35 is going to rub a little, but not too bad. Yes, stock is a 12.50 rim.
Try using the advanced search, and then the google toolbar for the search.
https://www.dieseltruckresource.com/forums/search.php
Old Feb 20, 2011 | 04:41 PM
StealthDiesel's Avatar
The stock SRW wheel on 3rd & 4th Gens is 17x8. The dually wheel on 3rd & 4th Gens is 17x6.
I recommend a test fit.. Mount 1 tire on a wheel. See how the tire fits the wheel & then test fit it on the truck.
Old Feb 23, 2011 | 07:05 PM
Festus's Avatar
It has been recommended 8.5 -11 on the website. I'm thinking 8 might just be close enough for me.
I'll make it through the rest of winter and all summer with as much as I actually get to drive the truck, but I will need by the end of August for sure.
Old Feb 23, 2011 | 07:28 PM
Tate's Avatar
I had 33x12.50 on 15x7 rims years back when I had my 4by F-150. Was a tight fit, but they worked. 8" would be much better, but it still might wear out the middle quicker than the rest.
Old Feb 23, 2011 | 07:38 PM
Festus's Avatar
True enough. Why must you point out these very true details? You and Kevin really like to spend others money. Soon, I will have twins too.............buggers
I was trying to get away from the cost of rims too. 35" tires are spendy enough.
Old Feb 24, 2011 | 08:57 AM
JHansen's Avatar
I've run 35x12.5R17 on the stock 3G rims on my '01 for quite a while now. They work-but the centres do wear a little quicker with the 8" wheels. I dropped the tire pressure some to compensate as I never ran close to GVW at that time.
HTH
Jason
Old Mar 2, 2011 | 06:09 PM
magiriano's Avatar
I thought 34" is the most you can fit on a stock rim. Got that - 305/70R17 with 2" leveling and no rubbing
roughstock
Dec 8, 2009 10:29 PM
Joe T
13
Jul 10, 2007 11:14 PM
Hoss
Dec 10, 2005 02:30 AM
