Replace P7100 ??? *gulp*
Old Dec 6, 2008 | 01:00 AM
ScottN's Avatar
Looks like my fuel rack/plunger/something is sticking inside the pump.
Throttle was stuck up. Then stuck down (idle, hard throttle, could not push). No indication of linkage problems.
Sure was fun bringing it from Ponoka to Edmonton with no guarantee of power, or the choice of what power level.
Anyway, it mostly liked to stay stuck at about 2500 rpm depending on load. By the time I got back to Edmonton it was acting mostly normal, but noticeably less smooth on the throttle engagement.
So... is anyone good at P7100 pulling/installing and timing? I don't know that I have the time + skills + tools to do this properly on my own (well, I know I don't have the tools, time could be tight, especially once I get a presumably rebuilt pump... it appears going into these is a no-no for people at my level, and...)
Any other ideas?
Good 'ole mechanical engine though... still got me back to town to switch to a different vehicle. And had I been really desperate for time, I would have just kept going to Calgary...
I'm afraid I might have to buy a temp replacement vehicle!
Old Dec 6, 2008 | 01:54 AM
Dr. Evil's Avatar
Scott, there might be a couple of guys that can help here.
Old Dec 6, 2008 | 02:10 AM
Tate's Avatar
If worse comes to worse, call Kenny about that 95 for $2k. That would be a good temp vehicle.
By rights, you don't need any special tools to remove or reinstall a p-pump. Basic hand tools. When you go to reinstall the pump, pin the motor, and pin the pump. That will get you timed to whatever the shop sets the pin at in the pump, probably around 16 degrees if you send it off to a performance diesel shop, probably 13 if you just get a stock rebuild.
Where are you looking to send your pump? I've heard good things about Columbus diesel, that will be where I send my pump whenever it comes off, sometime next year likely.
Old Dec 6, 2008 | 03:19 PM
1-5-3-6-2-4's Avatar
I went and upped for the snap-on p7100 timing kit. so tate has one and i have one.
Old Dec 7, 2008 | 09:11 AM
JHansen's Avatar
Don't suppose it happened in the mini cold spell we had? My brother's '98 is infamous for freezing the throttle cable and doing almost exactly the same things you're describing. Might be something as simple as that...
I have the timing tools as well-but have yet to fully use them.
Jason
Old Dec 7, 2008 | 10:31 AM
Mike Holmen's Avatar
The Guru
You should bring it to next weekend GTG. We can take a look at her for ya. Nothing else we could see what timing you have set-up. A few guys here are pretty good at tuning the older P pump trucks.
Old Dec 7, 2008 | 11:07 PM
Lil Dog's Avatar
P-Pump power baby!!! It is not an uncommon failure for the pump from what I have read. Earlier years seemed more prevalent.
Old Dec 8, 2008 | 08:52 AM
Swamp_Donkey's Avatar
I also had the frozen throttle cable issue. It was a little random... and scary at times!
Old Dec 8, 2008 | 09:06 AM
On another note, if you think you might try replacing your throttle cable, a throttle cable is well over a hundred dollars I think. There was a TSB out for something to do with the throttle cable....... fraying I think. Anyways the tsb throttle repair kit is about 1/4 of the price. Just looked it up. It is a safety recall. http://dodgeram.info/tsb/recalls/970.htm Just give them this part #CANZ9700 It is for a 94-96 but might work on all years of 2nd gen 12v's.
Old Dec 8, 2008 | 10:20 AM
John Faughn's Avatar
I found a couple of good prices , if that's what you need .
Anybody know of these outfits , I need go get one , but haven't heard of them until I did a search ?
http://www.competitiondiesel.com/for...ad.php?t=14085
http://www.usdieselparts.com/category.cfm?Category=1009
Old Dec 9, 2008 | 12:26 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
10-4....Mine died on my 95 two years.Not to bad to replace,but there is one bolt that is a really pain,one that connnects the pump to the motor.A long extension and a unversal fixed that problem.
Battering Ram
15
Feb 1, 2011 02:46 PM
dieslcruisrhead
Jan 19, 2005 09:50 AM
GO 4LO
Dec 31, 2002 08:08 AM
fboese
0
Dec 10, 2002 04:01 PM
Don M
Oct 29, 2002 03:00 AM
