Need a New Front Driveshaft
Old Jan 9, 2011 | 11:54 AM
HDBeauty's Avatar
Hey guys....Anyone know of a good shop in Edmonton where I can get a new front driveshaft? I destroyed my stock one while 4x4ing. I am pretty sure I need a whole new assembly because the ball and socket it toast and that double u-joint is grenaded. I need one really bad and need to find one ASAP?
Also, does anyone have a picture of the driver side of a Getrag 360? When I destroyed the front U-joints it knocked a bolt or plug off the side of the tranny and I lost my tranny fluid. Now I need to figure out what plug or bolt I need.
Thanks
Old Jan 9, 2011 | 12:51 PM
roxxx's Avatar
Geeez YOu must have being really floggin the old Girl to knock
Did you break the bolt or was it backing out ? if its broken you may have bigger issues
http://pc-guy.ca/Dodge/Getrag-pdf/GetragG360.pdf
here this may help you EDIT dang it I cant see the bolt in the PDF i do know which one you mean though
I have a getrag truck under a tarp if the wind and snow lets up i will go over and try and trakin a picture for you no promises its friggin cold out and not sure how much snow is under the truck
EDIT
Try Po-po's in Lacombe I know they have 3 or 4 getrag trucks Reg's may have on in lacombe too. Po po's can be pricey. so phone them and then phone to see how much a new one will cost I know Pats drive line will make you one may be a bit Spendy too but its new. Some else may know of a good drive line shop in your area
Old Jan 9, 2011 | 05:11 PM
Tate's Avatar
Call Drive Products. I used the one in Calgary to shorten and rebuild both my driveshafts for my 6 spd swap, was about $500 for doing that. Looks like there is two of them in Edmonton.
Old Jan 9, 2011 | 08:08 PM
HDBeauty's Avatar
This is the hole in the Getrag that I am talking about..What is supposed to be in there?
Old Jan 9, 2011 | 08:13 PM
Flanman5's Avatar
A1 driveline in Grande Prairie. Cheap and buses that day.
Bowser50
33
Jul 21, 2013 06:33 PM
HDBeauty
Jan 31, 2011 05:17 PM
reecegr
Feb 10, 2008 05:43 PM
cquestad
18
May 18, 2007 01:47 PM
