Need an engine for a 2003 3500 or a rebuilder in Calgary
Old Sep 22, 2008 | 01:41 PM
  #46
Mike Holmen's Avatar
The Guru
I have a heavy duty ball joint press, I have the upper out now, just those bottoms are a real bugaboo. The bottom of the axle is angled and you can't get a good even push on them. Dodge told me that they can get it in on Wednesday, and I've done all of the work, so it shouldn't be too pricey. The truck should have some pretty jewerly hanging on it after this all done. Maybe I can hang with you cool dudes at the next GTG without bring a gaser to the party.
Old Sep 22, 2008 | 01:44 PM
  #47
Marine's Avatar
Veteran: Marine Corp
Mike,
I am in Calgary right now- How much to do my ball joints if I help and supply the parts?
Old Sep 22, 2008 | 04:42 PM
  #48
Dr. Evil's Avatar
$300 if you watch
$500 if you help....
Old Sep 22, 2008 | 04:50 PM
  #49
Marine's Avatar
Shane,
those are your prices....
Old Sep 22, 2008 | 05:42 PM
  #50
Dr. Evil's Avatar
Nope - Just a guideline - Mike might want to adjust his prices
Sorry, we now return you back to Clayh's blown engine.
Old Sep 22, 2008 | 06:09 PM
  #51
Marine's Avatar
Lol.
I guess he didn't find out what is wrong with it yet?
Old Sep 22, 2008 | 09:18 PM
  #52
cLAYH's Avatar
Not yet, I have Friday off so I'm going to try really hard to get the pan off.
For those ball joint presses I find it works well to wack the end of the press(the screw) with a hammer, then tighten, then wack....repeat as needed. Haven't had to resort to heat yet.
Old Sep 22, 2008 | 09:23 PM
  #53
Marine's Avatar
cLAYH,
I'll be in Cochrane on Sunday. Will you be around?
Old Sep 22, 2008 | 09:57 PM
  #54
Checkmate's Avatar
You do NOT have to pull trans to pull engine. It's all in how you hook up the lift chain. you want to pick it up nose down instead of the usual nose up. This will allow the valve cover to clear the cowl and then allow room to lft over cross member.
Old Sep 22, 2008 | 09:58 PM
  #55
JHansen's Avatar
IIRC Mike the OTC/Miller adapters are angled to get a straight push on the ball joint with the tool. Probably a good call to haul the axle down to the dealership and let them fight with it-I'm not bright enough to make a decision like that!
Jason
Old Sep 22, 2008 | 10:00 PM
  #56
JHansen's Avatar
How do you get the input shaft clear of the clutch without sliding the tranny back? Couldn't see any way to do it on my BR-maybe a DR is different.
  #57
Marine's Avatar
He has to pull the transmission in order to put my auto in there.
Old Sep 26, 2008 | 09:09 AM
  #58
The Guru
I found out why my ball joints was so stuck. The hubs were toast. Both sides. They had to beat them to come apart. I can't believe that those bearings are so pricey. They are $450 a piece.
Anybody have an idea on you prevent that from occurring in the future?
Old Sep 26, 2008 | 09:34 AM
  #59
Marine's Avatar
Mike,
Do you have any pics?
Old Sep 26, 2008 | 11:22 AM
  #60
The Guru
Nothing fancy here its been a slow process put everything back together.
Correct me if I'm wrong on pulling an engine. Remove head, intercooler, rad and bumper. The motor mounts come out. Unbolt from tranny. It should just slide forward. There at least of 4in of movement. Angle/lift the motor for the sump to clear but it should come out. Am I missing something. I wouldn't completely remove tranny, if should just slide backwards with the TC case attached. I just rested my tranny on top of the tranny brace. Theres lots of room. You have to remove the tranny support. The tranny brace you have to beat out and press bac in.
You of course have to remove the axles to do this. I've pulled my converter this way. I've never removed an engine completely, just everything around it.
