Here are some of my thoughts regarding my truck,, what do you think?
Probably one of the worst failure we seen, besides that 12V
we got. Thinking about how the oil poured out still makes me laugh
with its marshwellow burnt looking piston.
yeah, the big difference between yours and mine is that mine is a 6.7 block, which changes the angles etc. I am also considerably heavier fueled than yours. If I was building a 5.9 it would be like yours though for sure
I'm still putting together a CR engine parts list & procedures that came from discussions on a local CR engine failure/rebuild earlier this year.
While Kevin's race truck is way beyond anything that most of us will ever have, would the forged 12V rods be fine on the street for a good running, dead reliable 600HP CR?
What other reasonable rod options are out there?
Not sure about that Brett. That motor has been apart a few times. I wanted to say it spun a bearing first, than smashed the piston into the head. The shop that did the machine work says its common failure, same goes for the cam bearings issues.
with its marshwellow burnt looking piston.Yeah that 12v was gross, it was like black whipped cream.
The crazy idea of pulling my engine & fixing the CR weakpoints has crossed my mind.
It would soooo easy on an engine that's in good shape. Quick hone on the cylinders, 2003 coated pistons, new rings with greater end gap, 2003 nozzles,
machine off the cast intake, balance it all. Done!
Doing that in a controlled fashion rather than reacting to an engine problem or failure would be so much better, but who has the time & money to do that?
Back to connecting rods...
It looks like the Cummins forged rods would be a nice peace of mind upgrade for a low power engine that tows a fair bit like mine.
They're available everywhere for reasonable cost. Plus prep plus balancing.
http://www.motorsportdiesel.com/stor...-10721529.aspx
Are there any rod options between the $2500 R&R's or Carillos & the OEM forged rods?
Whats your end goal Joe? For a 500 hp tow truck, I think what you're looking at is way over kill. 625's is way over kill. All the more power to you if thats what you want to do, but unless you're flirting with 4 digit power, most stock components are fine. The early piston/injector combo would definitely be a step in the right direction. But thats a lot of work to fix an issue that normally doesn't show its face unless you're running a Smarty and dual CP3's. If you're gonna pull a CR, put a 12v back in it, if you're looking for reliability and simplicity.
. Hate to throw this out, but lots of guys have run near stock trucks and make big power with them.
All excellent points & good discussion guys but wait until I start a new thread instead of cluttering up Kevin's race truck discussion.
Sorry about that Kevin, back to the original topic...
Joe, these things need to be discussed.
If you melt down at some point, I hope you would feel comfortable to allow us to get you back so you can run again. Aftermarket rods in a daily driver non puller/non drag truck is over kill. I would wait till something occurrs, throw in a set of 12V's rods.
I want a 6.7L to make some local Alberta power. Way to many have heard way to many stories of 6.7L issues, but don't believe any of them.
I will be building a 5.9L with the works. If you want to stop by and ask whats up, you bring the beer. Those banks intakes plenum cost around $700.
http://www.competitiondiesel.com/for...ighlight=42747
If you melt down at some point, I hope you would feel comfortable to allow us to get you back so you can run again. Aftermarket rods in a daily driver non puller/non drag truck is over kill. I would wait till something occurrs, throw in a set of 12V's rods. I want a 6.7L to make some local Alberta power. Way to many have heard way to many stories of 6.7L issues, but don't believe any of them.
thenrie
Feb 4, 2016 12:47 PM
bridleman
Oct 12, 2008 04:27 PM
Dodgezilla
Sep 1, 2008 05:49 AM
snowmanx
16
Jul 24, 2007 07:25 PM
kas83
Jul 22, 2007 04:32 PM
