Fuel pump
Old Feb 7, 2010 | 01:52 PM
  #31
Doj Dewd's Avatar
Originally Posted by pind
don't bother extending the pump shaft, although a good machinist could do it with no problems, it would create a weak link in the system. Simply modify the mounting bracket to move the pump farther out to reach. And those cog belts are available in an amazing variety of lengths, to suit any application.
The pulley for your damper would simply need a spacer behind it, to work with your configuration, if the damper is deeper than stock.
much better idea to move the bracket forward (or make a new one) to clear the dampner.
the drive pulley is held onto it's shaft with a set screw. the other end of the shaft is reverse threaded into a machined piece which bolts to the dampner.
i would imagine you could purchase either mechanical pump and modify it to work with your setup. might take some time and effort to get it right - but once it's right, it's done.
kevin, do you have the diagrams on the MITUSA plumbing/kit? they are floating around on here somewhere - if you can't find them or have them - i can email it to you and then you can compare it to GDP's setup. from looking at the two - you would surely be able to figure out the plumbing on your truck.
Old Feb 7, 2010 | 01:58 PM
  #32
morkable's Avatar
I dont,, and that would be great
Thanks
morkable1@hotmail.com
Old Feb 7, 2010 | 04:31 PM
  #33
Dr. Evil's Avatar
Originally Posted by morkable
I know that Shane from Wicked Diesels was working on one, I will see what he has to say
I wouldnt trust that guy as far as I could throw him.
Old Feb 7, 2010 | 05:00 PM
  #34
morkable's Avatar
How come Shane? He has been pretty good with me so far, not that I have bought anything from him, but he phones me every once and awhile just to chat and see what I think of things.
I think I have found the solution to my problems, I found a AirDog II 240 on comp d,, that I have just picked up
Old Feb 8, 2010 | 01:30 AM
  #35
Doj Dewd's Avatar
forwarded the diagram/documents to your email kevin.
it sounds like you may be better off going the electric route with that airdog 240. i think it will save you a few headaches in getting the initial fuel system set up.
Old Feb 16, 2010 | 10:48 PM
  #36
Festus's Avatar
I was just going to suggest this AD. If you talk to Charlie, maybe they'll tweak one for you as well.
ScreaminEagle
Oct 31, 2007 03:31 PM
Stevie G
13
Aug 4, 2006 10:27 PM
Gene
Sep 10, 2005 09:32 PM
Commatoze
19
Aug 8, 2004 09:57 PM
TPilaske
16
Nov 22, 2002 08:15 PM
