Front axle
Old Feb 14, 2010 | 06:19 PM
03 ant a hemi's Avatar
Front axle
When doing the u joints on the front axle does one need anything special to remove the axle, do you have to go inside the diff at all or do they just pull out? How about changing the u joints themselves need a shop press or can a person use a hammer and punch?
Just wondering thinknig of tackling this tomorrow to try and track down the front end grinding on my truck.
Cheers
Old Feb 14, 2010 | 06:30 PM
winkdemon's Avatar
you don't need any special tools for doing it just pull it out but becareful that you don't cut the seal when putting it in ... and a vise and a hammer
Old Feb 14, 2010 | 06:32 PM
NoSparkplugs's Avatar
A couple of sockets for the cups and a vise is really all you need. A shop press does make a lot easier though. Remember to pull the c-clips out!
Old Feb 14, 2010 | 06:35 PM
winkdemon's Avatar
yep that work well socket and vise ,,, i just use a hammer ... but i have only done a few hundred
Old Feb 14, 2010 | 06:52 PM
I am doing these in the back ally so all I have to use is a socket and a hammer. thinking of that I need to buy a bigger hammer.
Thanks guys.
Old Feb 14, 2010 | 10:22 PM
winkdemon's Avatar
your trailer hitch and a jack stand works done that many times when i was on the side of the road
Old Feb 15, 2010 | 09:16 AM
rage_blue's Avatar
never done the trailer hitch trick lol I will have to remeber that one.
Old Feb 15, 2010 | 09:48 AM
thanks for the info. especially on the seal and ngreat idea using the hitch as a press.
Old Feb 16, 2010 | 07:36 PM
krh's Avatar
krh
make sure you have a backup tho. I dont know what these guys are talking about hammering the u joint out, i bent the handle on my arbor press trying to get my u joints apart.
Old Feb 16, 2010 | 10:07 PM
rage_blue's Avatar
shouldn't need that much force even on baddly rusted ones.
Old Feb 16, 2010 | 10:53 PM
krh's Avatar
krh
well they were brutally rusted, sure made a bang when i put it in the real press. and yes i did take out the c clips
Old Feb 16, 2010 | 10:59 PM
winkdemon's Avatar
farmer trick i guess . i have never used a press for a steel shaft , but i do on alum ones
Old Feb 16, 2010 | 11:32 PM
Mocho's Avatar
They pound out pretty easy once you've done a few, and a lot faster then a press once your good at it
Old Feb 17, 2010 | 01:17 AM
I bought a ball joint/universal tool, worked awesome.
csramsey640
Jun 4, 2014 10:31 PM
rustydeeretech
17
May 21, 2011 03:05 PM
case310350
Jun 23, 2010 09:03 PM
Hawkeye
Apr 29, 2008 10:24 AM
Paul Winey
Jun 22, 2004 08:09 AM
