Donkey Power. Engine build getting out of control.
Old Sep 17, 2009 | 10:13 PM
  #91
morkable's Avatar
Well, lets say this, I am not going to cut off my intake...
Old Sep 17, 2009 | 10:26 PM
  #92
Swamp_Donkey's Avatar
After more research I might do my own or I might just get a Banks twin ram thingamajigger, unless someone knows of some other trick piece.....
Old Sep 17, 2009 | 10:38 PM
  #93
Mike Holmen's Avatar
The Guru
I would say you need higher 6-7k rpm gov springs. 13mm pump, drop 2k lbs, but of course then you would have to fly cut the pistons. Get a bigger cam. Then those twins would be too small. I just mocked up a set of S366 over a T-88, its easy, throw in a decent size gate. Spray some drugs. It would be one fast truck buddy. Can I go for a ride? I can dream big ehh...I would trash what you have, and build again. Sell the old motor, then build the next one. 12v stuff is pretty decently priced, vs the new stuff. After that its just brains, sweat and dollars.
Old Sep 17, 2009 | 11:01 PM
  #94
I got no brains or dollars it seems! As for decently priced..... Just off the top of my head I am now probably almost 10,000 into this motor.... I think that is why it is taking me so long to build.
Just thinking of all the stuff I have bought for it so far.....
Camshaft & lifters.
4k gsk
Twins.
Rings
bearings
pistons
Water pump!
Fluid damper
Ats exhaust manifold
913 injection pump
ddp 4 injectors
Valve springs
intercooler boots
Boost gauge 0-100psi.
Lots of little odds and ends.....
May have forgot some stuff, who knows.
Old Sep 17, 2009 | 11:04 PM
  #95
And as for another motor, the guy who is helping me on this build is almost begging me to take an industrial 12v out of his shop with 6 hours on it..... I think I will take him up on that offer! There was something wrong with the cooling system on it and it melted out cyl #3.
Old Sep 17, 2009 | 11:13 PM
  #96
The Guru
Get that 12v motor. Free. wow.
It don't take long to push up the dollars. Let me know what you think of those twins. I think it will make you smile.
I have a new set-up a GT3788 over a S475, just about done. I have almost $3.5k just in turbos and stuff. I figure that I could get her done in 1-2 build days. Just kinda nervous on how good my head gasket is. My injectors mach 6'rs haven't been cleaned yet and I've been on the fence on trying a NOS set-up. Its been almost two years now.
Old Sep 27, 2009 | 10:19 PM
  #97
Thinking of putting in larger exhaust valves....... what do you guys figure?
Old Sep 27, 2009 | 10:24 PM
  #98
dvst8r's Avatar
Intakes work well for that.
Old Sep 28, 2009 | 09:33 AM
  #99
The Guru
Is both the valves have the same material?
Other than that, giver a try buddy on the intake valve into the exhaust. Its just parts. I was gonna do the same on my 12v build.
Old Sep 28, 2009 | 03:49 PM
  #100
Tate's Avatar
I hear SBC valves can work in the 12v head.
Old Sep 28, 2009 | 04:15 PM
  #101
The Guru
What kinda of material would you use if you went the SBC route? I was told that stainless wouldn't take the abuse of plus 1500 deg's pulls, but I could hopefully be wrong.
Are the SBC valves the same length and diameter?
Old Sep 28, 2009 | 04:59 PM
  #102
dvst8r's Avatar
I think the sbc valves have to be cut down, if I understood it right.
Old Sep 28, 2009 | 10:10 PM
  #103
What Harry at peak had mentioned was just using the intake valve and cutting it to that size. Never did ask if the valve was up to the temps...
Old Sep 28, 2009 | 10:35 PM
  #104
The Guru
dvst8r, the area on the top of the valve (where the retainer goes), is it heat treated. If its not, you could just trim on a lathe. I bet there is some kinda of way that they work that area as there is lots of stress on square corners of the cut. The valve tops could just pop off on a high rpm pull.
Old Sep 28, 2009 | 11:20 PM
  #105
dvst8r's Avatar
I am not certain. I just know that it is very common practice to use the intake valves as upgrades. Also a number of people machine for the 11/32 valve stem so you can use SBF valves, but the factory valves are already shrouded by the cylinder so there is only so much benefit going bigger.
