Check Engine light
Old Mar 17, 2008 | 05:30 PM
Ranger Bob's Avatar
Check Engine light
Hello, I added to my signature, I hope it come thru with this post. My question is does anybody have a reader that can tell me what the light is on for? The truck performs just fine so it is probably a warning light for tranny flush or some other Km deal. Just don't have it in the funds right now to buy one, and the edge juice for this year don't read codes.
Old Mar 17, 2008 | 06:39 PM
morkable's Avatar
One way to tell is to (while the truck is stopped and turned off) turn the key from the off posisition to the run position 3 times fairly quickly, then wright down the codes that it gives you and then I can tell you what they mean
Kevin
probably a 0603, 0700
Old Mar 17, 2008 | 07:15 PM
Festus's Avatar
Referring to this thread: https://www.dieseltruckresource.com/...d.php?t=197152
I couldn't get a code to come up on mine. Anyone around Edmonton with a scanner is my question.
I don't want to hijack this thread. Help for Ranger Bob is priority, but it seems too related to start a new thread.
Ranger, if you're from around here, we may be both asking to borrow/use one I think.
Old Mar 17, 2008 | 07:30 PM
DODGER BOMBER's Avatar
Where are you located. I can take my smarty off my truck for a few minutes and read your codes for you if you want. I live in airdrie.
Old Mar 17, 2008 | 07:39 PM
ICL's Avatar
ICL
Ranger Bob here, using ICL`s unit
code is P 0243
Old Mar 17, 2008 | 07:53 PM
Ranger Bob's Avatar
Hello DB
I live at ICL`s home, he`s my son-in-law.
Suppers on talk soon
Old Mar 17, 2008 | 07:59 PM
ICL's Avatar
ICL
code is P 0243
Using my unit? WTH! you are using my "computer" not my unit. Good lord.
Yeah DB if you don't mind, I will give you a call in a couple minutes.
Old Mar 17, 2008 | 10:30 PM
Ranger Bob's Avatar
Hello DB
Thankyou very much for your help.
Nice ride you have there.
Got to love these Dodges hay.
Again, thanks
Old Mar 17, 2008 | 10:38 PM
No prob. I just hope it stays off for ya. It wasnt like it was R&R'n a tranny or something. But ya nice to meet you guys too. have a safe drive tommorow
Old Mar 18, 2008 | 01:52 PM
morkable's Avatar
0243 is quite common, one of the by products of tuners
Old Mar 18, 2008 | 05:13 PM
Swamp_Donkey's Avatar
P0243 Wastegate Pressure Control PWM
What I found when I had this code was right on the solenoid on the turbo the wire had rubbed through the edge of the solenoid. Check yours out......
Old Mar 20, 2008 | 03:00 PM
Ranger Bob's Avatar
Check engine light
Dodge Bomber
Well as I was leaving the next day the light came back on.
I checked and it was the same code again.
I will check the wires and hopefully that is it.
Thanks guys for the help/
Old Apr 2, 2008 | 03:58 PM
Ranger Bob's Avatar
Hello
Thank you for that info, my book calls that code an overboost problem.
My boost has dropped from 36 to 23 max so it sure looks like a turbo issue.
Guess I`m looking for an ungrade, great.
Thanks again and I`ll keep posted.
Old Apr 2, 2008 | 11:14 PM
I have been living with 23 psi for over a year...........
Old Apr 3, 2008 | 07:49 PM
Ranger Bob's Avatar
Lost of boost and Edge Juice with A
DODGE BOMBER
I disconnected the Edge J and my cruise control works again so if we can get together on sunday over a twisty we could remove the code P0243 Wastegate Pressure Control PWM.
I can only read EGT`s on the E/J , but not boost.
Hope its not a wastegate problem, but then again it all about learning.
