Cheapest place to get the updated 3rd gen steering linkage?
Old Apr 17, 2011 | 05:16 PM
NoSparkplugs's Avatar
My 04 needs all new tie rods and I want to get the 08+ upgrade. I've been to two different Dodge dealers and they both said the TSB doesn't apply to my truck... (Dodge doesn't make my steering parts anymore and they quoted me roughly $850 for the new setup). Whereabouts can a guy get this setup without giving up a kidney for it? I read guys on here getting it for $250-300?? Where?. Kore has it for $500 but I'd thought I'd try local first.
Old Apr 17, 2011 | 05:25 PM
Danderson's Avatar
Source Automotive offers it w/zerk fittings.
Old Apr 17, 2011 | 05:59 PM
Thanks! I ordered it from them
Old Apr 22, 2011 | 08:41 AM
nickg's Avatar
I have the 08.5 set up on my 03, it was done when I bought the truck, just be aware if the tie rod is not sitting parallel to the steering arm, on a hard left or right turn the tie rod is well known to snap.
its easy to check and even easier to fix if it was installed wrong.
I'll try to find the post that had pics
Old Apr 22, 2011 | 08:55 AM
Danderson's Avatar
Excellent pt. A "neutral" install is imperative. It appears that some alignment techs leave the tre cocked fore or aft after adjustment.
Old Apr 22, 2011 | 09:07 AM
nickg's Avatar
cant find the link, I did save it as a PDF on my lap top, but its on the net somewhere..
here is a link with a pic of how the tie rod end wears
http://www.cumminsforum.com/forum/20...od-issues.html
Old Apr 22, 2011 | 09:43 AM
Mike Holmen's Avatar
The Guru
I want to build my front end with ballistic fab high steer parts. The OEM seem so tiny in comparison.
http://www.ballisticfabrication.com/...its_c_113.html
Half the problem is the weak tierod ends. Then its the ball joints and the steering gearbox. If you do any actual gravel road/off roading, its almost required stuff.
bradler
Mar 10, 2009 05:36 PM
woodrep
Feb 14, 2009 09:06 PM
storx
43
Aug 11, 2005 05:32 PM
