Case 930 comfort king power steering.
Old Jun 28, 2010 | 12:59 AM
Swamp_Donkey's Avatar
Anyone know where I can find a power steering pump for a mid to late 60's case tractor? Called Sexsmith used tractor parts and a few case dealers here and there. Got nowhere. I am thinking just about any power steering pump will work as long as it turns the right direction and a mounting bracket can be fabricated. But who knows! I am not a case tractor specialist by any means.
Old Jun 28, 2010 | 09:01 AM
morkable's Avatar
Have you tried googleing it? (I know you proably have, but just checking) I know that down in the states there are lots of guys that are really into the old tractor stuff.. Just an off shot did you try ebay? Also on Comp D there is a section for guys to talk about old tractors, that might be a good place to try too.
Old Jun 28, 2010 | 11:09 PM
pind's Avatar
Hey John
What is the problem with the steering? I might be able to help you out on this one... then again I might not. Depends how the UBI part of my brain is working at the moment.
Old Jun 29, 2010 | 01:17 AM
I am pretty sure for whatever reason the power steering pump is not creating any pressure at all. Something worn out in it i am thinking. Have not teed in a gauge to verify......
Old Jun 29, 2010 | 09:03 PM
pind's Avatar
tee in a gauge, just for fun... and because you know you want to.
I have seen a simple mechanical failure on some farm equipment, cause a problem that you would swear is the power steering pump, but turns out to be a loose nut behind the wheel, and not necessarily the current owner/operator.
cbtumedic
Nov 12, 2007 11:58 PM
rbrettctd
Jun 16, 2007 03:57 PM
benny852
Jun 16, 2006 06:29 AM
sdscuba
Nov 4, 2003 06:07 PM
92RamCTD
Dec 30, 2002 02:09 PM
