anyone doing vgt ?
Old Apr 6, 2010 | 09:53 PM
winkdemon's Avatar
anyone doing vgt ?
well i got a 6.7 vgt turbo today for cheap , i may put it on my truck , but i need some help with the manual part of it
Old Apr 6, 2010 | 10:22 PM
morkable's Avatar
I think you will need a controller for it. I beleive that fleece performance makes one
Old Apr 6, 2010 | 10:25 PM
winkdemon's Avatar
i was going to make , manual one
Old Apr 6, 2010 | 10:45 PM
morkable's Avatar
hmm,, I didnt know you could,, that would be interesting!
Old Apr 6, 2010 | 10:49 PM
Flanman5's Avatar
http://www.youtube.com/watch?v=BnHGb...eature=related
Would love this for mine too
winkdemon's Avatar
well it will by the boost acturator , i am thinking . i will play with it ,,
or i will buy some thing , or make asmall plc to run it , or it will sit on my deck and look cool
Old Apr 6, 2010 | 10:55 PM
roxxx's Avatar
I will scrounge around Wink i think some one has one on a 1 St gen some were
Old Apr 6, 2010 | 11:22 PM
Flanman5's Avatar
Where and what did you pay for it?
Old Apr 6, 2010 | 11:46 PM
northernwheeler's Avatar
Yeah, I got one too, wanted to put it on my '06, but life has been too busy to get after it. Shure would be nice to get a plug and play controller for it. There are a few people that rigged it up with small pnumatic cylinders to control it. I have a small cylinder I was going to modify so that it would work the same way as a wastegate actuator, but using a elctric three way valve you could also have the exhaust brake function too. The only thing is that you would need to have onboard air to operate it. i really do have to get around to getting it set up, just too many other things on the go right now.
Old Apr 7, 2010 | 12:12 AM
Flanman5's Avatar
Where are you guys getting them?
Old Apr 7, 2010 | 01:07 AM
Bought mine off eBay. Was less than a 100 bucks.
Old Apr 7, 2010 | 08:04 AM
JHansen's Avatar
Fleece is supposed to be coming out with a plug-and-play controller for the VP trucks for sure-I assume the earlier CR trucks as well? Think they are working on one for the 12 valve trucks as well.
Jason
Old Apr 7, 2010 | 08:31 AM
Mike Holmen's Avatar
The Guru
Rob, does all the electronic stuff work? Usually the electrical stuff is all burnt out. That's why typically they are so cheap. I would use a wastegate boost actuvator and a relay to run the e-brake. No electronics to worry about failing. Which truck you going to put it onto? Should be a sweet set-up, keep us posted on how it works out for you.
Old Apr 7, 2010 | 10:36 PM
winkdemon's Avatar
the turbo is new in the box , i got it from a warranty thing from dodge
Old Apr 7, 2010 | 10:43 PM
Scotty's Avatar
Top's Younger Twin
Some dealers have piles of them. Just gotta find the right one.
Most are fine, just sooted up. Some do have torched electronics.
I have two sitting here...for science.
Off topic but I am in the search for a full set of six 6.7 injectors...from a wreck or a blown engine. Hard to find and not cheap either.
Scotty
