Swap stock halogen to stock projector headlights?
Old 01-10-2016, 10:33 AM
Rollin'_Coal's Avatar
Does anybody know if the wiring on the factory projector headlights matches the wiring for the 2 or 4 lamp standard headlights? My truck has the 2 bulb garbage headlights and I just pulled the trigger on a factory order half ton diesel for the wife in a very loaded outdoorsman. Unfortunately, it will come with the standard 4 lamp halogen headlights as well. Has anyone tried to install the newer projector style headlights in an older 4th gen that didn't have them? I'm perfectly comfortable with cutting wiring and soldering on different sockets if required and I have a scan tool that should be able to switch the headlight settings in the tipm. Just wondering if they will fit or even just plug and play?
Old 01-16-2016, 09:33 AM
Bump...
Nobody has had to take a projector headlight out of a 4th gen yet?
Old 01-25-2016, 05:23 PM
arcticzale's Avatar
It will not match up. But you can get harnesses from here: https://shop.retroshop.us/SearchResults.asp?Cat=1828
I actually went back to the quad lamps and HIDs since it was better light dispersement. But to each his own.
Old 01-28-2016, 06:57 PM
Gry113500's Avatar
My buddy put them in his '12. He got the stock 13+ projectors and a harness, they work well. I have LED's in my stock 4 bulb headlights and they both put out roughly the same light
rfeiller
34
10-21-2008 06:22 PM
Death Dealer
16
11-08-2007 08:09 PM
Alec
09-08-2004 07:59 PM
rattle_rattle
08-10-2004 04:03 PM
KATOOM
06-06-2003 11:12 PM
Quick Reply: Swap stock halogen to stock projector headlights?
