ignition switch acts funny!
Old Feb 18, 2014 | 02:34 PM
smokey94's Avatar
I have a 2010 6.7 mega cab. I bought I used and it only came with one key fob. When I go too start it sometimes it cranks right away sometimes you turn the key and nothing happens . the radio comes on but wont crank over so you turn it off and it will start. sometimes it takes several times to get it to start.
Old Feb 19, 2014 | 01:25 PM
Busboy's Avatar
My first thought is the one key fob you have is not being read by the ECU every time. I would get another one programmed and only use that one to see if that is the problem.
Old Feb 20, 2014 | 05:00 PM
cbrahs's Avatar
they have a known issue with the wireless module (ignition switch). mine has done it from day 1. very hit and miss but i cycle the key and it works.
Old Feb 21, 2014 | 08:25 AM
6.7L MegaCab's Avatar
My truck has done the same thing. Try replacing the batteries in the FOBIK. I've notice my keys behave differently when the batteries start getting weak. I thought there was a TSB for the ignition module, but it may have been for the key popping out.
Sent from my Nexus 5 using Tapatalk
Old Feb 21, 2014 | 10:59 AM
cbrahs's Avatar
if i remember right the tsb was for the module not releasing the key when shutting truck off and removing key from module.
Old Feb 21, 2014 | 11:09 AM
I don't know why a smiley showed for the TSB number- needed a space after the 8.
Close. I just looked it up. It was for the key releasing in any gear but park. TSB (K08 ) mentioned the WIN module requires replacement if the FOBIK can be removed in neutral... something about running through the check about 50 times and if it comes out in neutral, replace the WIN module.
matt69olds
Jan 27, 2009 07:47 AM
Mopar72
Dec 5, 2008 08:16 PM
AviatorOne
Dec 15, 2005 06:46 PM
luv2smoke
0
Jul 13, 2005 10:31 PM
cLAYH
Jun 7, 2005 04:16 PM
