debadging
Old May 8, 2012 | 06:13 PM
dodgebre3500's Avatar
debadging
debading truck emblems, any tips on getting the sticky tape off the truck besides my thumbnails. thanks
Old May 8, 2012 | 07:49 PM
Dr.Dizzle's Avatar
Removing the adhesive residue will require rubbing it away with a rag dampened with some form of solvent that breaks down the adhesive. The 3M General Purpose Adhesive cleaner #38983 is very effective. However, rubbing alcohol can be used but is not as effective as the 3M product. If you opt for the rubbing alcohol, you will need to apply much more elbow grease in order to remove adhesive residue completely. I also recommend using a micro fiber towel which will keep scratching of the underlying paint to a minimum.
For stubborn areas, 3M markets an eraser wheel or stripe removal wheel that chucks onto a drill. This will remove the adhesive in no time.
Old May 8, 2012 | 07:51 PM
Kidrod's Avatar
WD-40 works with a little elbow grease and a rag. Toluene solvent works really well and is available at an ACE hardware store. Gasoline works also. Make sure you clean the residue off the paint.
Old May 8, 2012 | 09:07 PM
debadge
ok thanks guys,just finished the drivers side [2hrs],blow dryer works good on the thick tape,now the other side, looks good thou
Old May 9, 2012 | 09:51 AM
Beast2B's Avatar
Wow. i haven't done the 4th gen yet, but the 2nd gen emlems came off in less than 10 minutes using braided fishing line. The WD40 method took another 10 minutes, but worked like a charm as long as a good wash and some wax are applied soon after.
jonesm8
14
Dec 11, 2006 11:36 PM
Red3quarter
Jun 25, 2006 08:59 PM
Jeepin951
Apr 3, 2006 06:27 PM
WACTD
47
Apr 3, 2006 01:16 PM
KatDiesel
Jun 11, 2003 03:58 PM
