what level should i set my injection timing at?
Old Jan 8, 2014 | 03:30 PM
smokey94's Avatar
I just got my mini max for my 2010 . it has 5 levels of injection timing 1 being lowest 3 being default or stock 5 being most aggressive. is it hard on the injectors on 5? or will it build too much egt? or just turn it all the way up and roll
Old Jan 11, 2014 | 01:01 AM
6.7L MegaCab's Avatar
Unless you have other supporting mods, such as ARP head studs and fuel mods, I would keep it at the default level. That is where I keep mine and when I'm easy on the throttle, I'll squeeze out about 20mpg to/from work (around 70 miles round trip).
Sent from my DROID X2 using Tapatalk 2
Old Jan 20, 2014 | 01:16 PM
cbrahs's Avatar
H&S stock tunes are heavy on timing so keep default and I personally would also not go above tow mode. I have MCC on mine and it runs awesome. 40psi boost out of stock turbo. no studs (my tuner is running a S475 @ 50 plus psi boost with no studs and ZERO issues).
Old Jan 20, 2014 | 01:18 PM
cbrahs's Avatar
also my custom MCC tune that I am running pulling my 15k toy hauler at 90mph uphill gaining speed, EGT's never got hotter than 1230 degrees.
RollsCoal
Feb 23, 2010 09:23 AM
Common
Jun 20, 2007 07:52 PM
HO Cummins
Apr 25, 2007 02:09 PM
halerazor
Jan 12, 2005 10:29 PM
teckert
Jun 9, 2004 12:34 PM
