I set my timing at 15.5* what should I expect?
Old Jun 19, 2007 | 05:50 PM
Common's Avatar
And will my HG be O.K.?
Old Jun 19, 2007 | 06:53 PM
atc250r's Avatar
15.5* is pretty conservative, it should be fine.
John
Old Jun 19, 2007 | 07:54 PM
Common's Avatar
Should I get an increase in mileage?
My running temp on the freeway @ 65 is 500-550F
Old Jun 20, 2007 | 12:24 AM
mr T's Avatar
your mileage may increase a lil bit but don't expect miracles...your egt's should drop....engine will clatter slightly more...crackling /popping will be gone durign cold starts in the winter....and popping will be gone at higher rpms.....it will rev up smoother without stumble at higher rpms......truck will feel peppier ...kinda like it lost weight....engine will feel "lighter" as it revs...thats the feeling I can describe when I had it done
Old Jun 20, 2007 | 12:37 PM
b.lee's Avatar
I need mine done bad... ;(
Old Jun 20, 2007 | 06:24 PM
Common's Avatar
Any long term effects? Bad?
Old Jun 20, 2007 | 07:50 PM
Paul Winey's Avatar
DB:
Glad to see you got the #10 in. With that in the stock position and being your only fuel mod you will be fine with the 15.5*. Mr T gives a good description. It will sound as if the engine doesn't have to work as hard when cruising down the road.
Only long-term bad effect is that it might leave you wanting more .
Seriously, 15.5 is very conservative and will keep you and the HG safe. I would however, strongly consider the 3K GSK as a next mod. It doesn't necessarily add more fuel but lets you use all that you have better.
Paul
Old Jun 20, 2007 | 07:52 PM
atc250r's Avatar
I don't think so, especially with the conservative amount you bumped it up. The stock timing is quite a bit below what is "optimal" in order to reduce emissions. I think its NOx emissions that go up as timing is advanced but I'm not sure. I went from 13* to 17* and noticed an immediate improvement in throttle response. It also took noticeable less throttle to keep the truck at highway speed. Plus the throttle response is much better and there is a lot more "top end" in the motor. I haven't filled up since I had it done so I don't know what improvement I'll see in the fuel mileage department.
John
smokey94
Jan 20, 2014 01:18 PM
RollsCoal
Feb 23, 2010 09:23 AM
HO Cummins
Apr 25, 2007 02:09 PM
greenwing
Feb 20, 2006 05:35 PM
halerazor
Jan 12, 2005 10:29 PM
