on a stock truck...Airdog?
Old Mopar Aficionado Extraordinaire
I run a Catapillar filter after the air dog. That's a 2 Micron. So double filtering is even better. The Cat filter has a separator in it too. Every now and then I find a couple of drops in there too. I drain about once a month
Takes several hours. You need to drop the tank for the draw straw and install the mounting bracket. Once the tank is done, it goes pretty quick.
Make sure the hose is positioned not to chaif.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
draw straw not used anymore (at least on FASS pumps). they are too much of a pain in the rear. majority of the 1/4 tank issues is due to the draw straw sucking air at the plastic/metal union. Just like poking a hole in your buddies straw while he is drinking a coke. when its full, its easy to pull the cola out. lower the glass gets the harder said buddy has to work to get any cola. same theory with a draw straw (THEY SUCK LOL)
both FASS and Airdog have a new fuel pickup system that is retro'd right into the stock fuel canister. no more drilling your tank, uses OEM feed line fitting on the canister as the return (no more cutting filler neck hose from what I am being told) which returns fuel into the canister basket which keeps the basket full of fuel at all times. I am waiting on the new system from FASS as they are just releasing it but the bad thing is that everyone that has pumps in stock will be getting rid of their old stock first so you will probably get a draw straw that comes with the kit until old stock is depleted and new stock (with retro kit included) is on the shelves. all of the FASS pumps come with the new retro kit (june 1st production and newer) as they all came with the draw straw before. that is why the price increase as of June 1 for FASS.
I am just waiting to see one first hand as to wether I will use it or not.
oh, did a platinum on a 2011 dodge dually a few weeks ago. FASS stepped it up and on the harness its TOTAL plug and play. no more cutting and splicing into the factory harness for the trigger wire. they "Y'd" the factory fuel can harness so its a click click done
kdbvulcan
20
12-06-2008 04:34 PM
Bobcat698
09-29-2008 07:08 PM
jentas
33
03-07-2008 02:45 PM
