obd port lock?
Old Jun 28, 2013 | 02:10 PM
iforge03's Avatar
obd port lock?
Does anybody know of a way to lock up the obdII port. i need to take my truck in to have the windshield washer reservoir fixed under warranty and i want to make sure they cant get into my ecm, as they have no business getting into my ecm, but who knows what they do when you take you in. any ideas?
Old Jun 28, 2013 | 10:49 PM
6.7L MegaCab's Avatar
I've tossed around a few ideas, but if you are worried, I would unscrew it and zip tie the obd port somewhere high and out of sight under the dash...even go as far as taping the end really good in case they have someone that likes to seek destruction when you hide something from them and they search for it and if found, they may try to plug into it....but if its taped and hidden, they shouldn't even bother.
Sent from my DROID X2 using Tapatalk 2
Old Jun 29, 2013 | 02:28 PM
Jordan5687's Avatar
I am very interested in this as well. I have 2 trucks I need kept locked. Although h&s has done a great job on thier product and not needing to return to stock. All you gotta do is reflash after dealer. But theres always that chance.
Old Jun 29, 2013 | 02:32 PM
iforge03's Avatar
thanks for the idea megacab, ill have to give that a try
Old Jun 29, 2013 | 04:54 PM
Busboy's Avatar
If you loosen the wires just a little the whole OBD2 port can be inverted and mounted back into the same location, this works well if you have a programmer plugged in as it gets it up out of the way.
Old Jun 29, 2013 | 05:11 PM
Totallyrad's Avatar
With the truck under warranty still if they happen to look don't you think the port being missing or covered might cause them to investigate further? Just asking?
Old Jun 29, 2013 | 05:19 PM
Totallyrad's Avatar
I suppose a cheap way to disable it and know if they tampered with it would be to go to a truck stop and buy a couple door seals like they put on the cargo doors of a semi trailer.
Old Jul 1, 2013 | 11:04 AM
Beast2B's Avatar
and make sure the service order says DO NOT FLASH and is signed by you and the service writer. even talk to the tech if you can before they work on it.
onehitwonder53
Mar 3, 2015 08:03 AM
Polarlys
Jan 26, 2011 10:05 AM
CTD NUT
Mar 10, 2010 01:28 PM
MikeyT
Nov 22, 2009 01:27 PM
