Pin-outs for an 03 OBD/Data Link port
Old Mar 10, 2010 | 07:46 AM
CTD NUT's Avatar
Well, I have come to find out that the OBD/Data Link port connector is mangled on my truck. I was able to obtain a later model replacement connector from the dealer. However, when it came time to install the replacement connector and figure out the the pin out locations, I came up with nothing so far. I have looked at the online body builder pdf's from Dodge but it only goes back to 04. I figured 03 and 04 data link port connectors must have the same wiring, right? No, they do not. It turns out it isn't even close. The 04 uses 5 wires and my 03 has 7 wires and not only that, there aren't even ANY common wire colours between them. Crazy.
So, I'm hoping someone here might have the pin out diagrams for 03 electrical connectors? Anyone? Help! I can't plug a scanner in until this is fixed....
Old Mar 10, 2010 | 09:22 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
schematic page from manual
I think this is what you need. I have an '03 as well and this is the online CD pdf manual I've been using. It shows 7 wires to the data link plug as you said. Hope it helps.
File Type: pdf
Old Mar 10, 2010 | 01:28 PM
CTD NUT's Avatar
OOOO - thank you! I think that is going to work nicely. The pdf actually shows 8 wires...hopefully, I mis-counted? I'll try my luck with this tonight.
Thanks again....
onehitwonder53
Mar 3, 2015 08:03 AM
iforge03
Jul 1, 2013 11:04 AM
Polarlys
Jan 26, 2011 10:05 AM
MikeyT
Nov 22, 2009 01:27 PM
tex23455
Jun 7, 2007 03:30 PM
