Line of fire tailgate light
Just installed Recon line of fire and left turn signal doesn't work. I have it plugged into the 4 point harness and the truck is brand new any ideas?
I checked the blue 20 fuse under the hood its good.
Check for any grounding issues. Usually the first sign of electrical trouble.
Id also grab a voltmeter or test light and make sure that you have the left turn working at the 4 pin plug. If so, its an issue with the bar. If not, issue with the truck wiring.
Puke
May 8, 2007 10:04 PM
hump
42
Nov 30, 2006 02:14 PM
Lathe Guy
Apr 24, 2006 02:09 PM
