Filter back 5" exhaust
Old Dec 17, 2012 | 12:52 PM
Rollin'_Coal's Avatar
Question Filter back 5" exhaust
First off, unfortunately, I CAN'T DELETE YET...
I have a very sticky dealer when it comes to warranty and they're the only one in town. I want to do deletes but am waiting until at least the end of summer.
Has anybody installed, or seen a truck with a 5" DPF back exhaust? I understand it won't have any power gain but going up to a 5" with no muffler for the tail pipe section should in theory have a nicer sound right? I'm going strictly for looks and sound at this point. I've heard pulling the muffler and staying with the stock 4" makes zero difference If anybody has some suggestions or insight I would greatly appreciate.
Old Dec 17, 2012 | 03:05 PM
Busboy's Avatar
Not sure if you have seen the pic looking straight through the factory muffler, no restriction at all.
Old Dec 17, 2012 | 03:14 PM
I haven't seen a picture but I have heard that. Any input about the upsize to 5" changing the sound to a deeper tone?
Old Dec 17, 2012 | 03:27 PM
Busboy's Avatar
I like to fly under the radar so to speak but... I also kept all the bits that were causing problems just in case for what ever reason I needed those problems to return. I kept the factory down pipe to make life easier also. The turbo is a 4 inch outlet into that factory 4 inch down pipe so there is your restriction at the turbo. So long as you do the CCV delete (less than $2) the turbo should last awhile and it works well.
TBH I would wait to see IF you can get through the winter with the truck stock..just saying. If you HAVE to delete your plans will change.
Old Dec 17, 2012 | 03:51 PM
I don't quite follow, what is a CCV delete? Why would my turbo not last awhile? And if you're referring to the DPF giving me winter issues, I try to drive it like I stole it at least once a week and haven't had a regen warning in my first 20,000 km's and I idle way more than I should.
Old Dec 17, 2012 | 05:08 PM
Busboy's Avatar
CCV crank case vent, that's the hose about 1 inch diameter that enters the intake air duct directly in front of the turbo intake. All the oily gasses from the crank case are compressed and deposited on the blades and throughout the inter cooler. By plugging the intake and either routing the CCV hose down to the frame of installing a CCV filter in the end of the hose gets rid of the mess on the blades. It does not take long for dirt to build up on the blades as the oil is catching it. As for the regen I never had one either or any codes it just about always had a trailer behind it, until winter came then one short trip to get parts to delete the other truck and it threw O2 sensor codes. Life is too short to spend it in line at the dealer.
Old Dec 17, 2012 | 05:53 PM
Busboy's Avatar
Ah ha, I see you now moved from Ft St John to warmer climes.
Old Dec 17, 2012 | 06:10 PM
Indeed I have. Still working up north in Alberta though. I did some reading on the CCV, once I read the first words I figured it out. So, did you just plug the line or completely gut the filter housing and leave it to atmosphere? I looked at a kit glacier diesel has and I could easily do it there way for about 10 bucks with the crank filter and hose elbow.
Old Dec 17, 2012 | 06:26 PM
Busboy's Avatar
I just used a plastic 1 inch plug into the intake, recently Blake posted a pic of his steel one same as mine but plastic doesn't rust. The hose coming from the crank case I removed and replaced with 3/4 inch heater hose and ran it over to the passenger side then down to the frame, more rust prevention. I don't have a Egr cooler anymore so mine is quite open. My concern with using a filter on the end of the hose was the condensation might freeze.
krazydher
17
Mar 6, 2010 10:23 PM
Big Green11
May 2, 2008 07:08 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
getblown5.9
83
Sep 30, 2007 03:08 AM
Dieseldude4x4
Oct 17, 2004 11:07 PM
