Egt's. Is this possible?
To start I'm fully deleted with the H&S XRT pro. My exhaust temps seem to be way low compared to what I'm used to. Running empty with the setting on the mild setting with turbo set at 4 on fuel default I never see above 900 on the exhaust temps. When I pull my travel trailer fully loaded I have yet to see above 1200 egt's. I assume the trailer weighs about 10,000. Im running isspro EV2 gauges gen 2s. Boost I have seen spike at 32-33 psi. I have tested the thermocouple with a torch and I can get the egr gauge to spike at 1600. Are these temps possible?
Sounds pretty much just how my truck ran before the new turbo was installed. It would average 750 to 800 cruising 70 (2100 rpms) and 800 to 900 at 75+ (2300-2400 rpms). Never seen anything higher than 1200. This was H&S on mild, no turbo tuning, default timing.
Thanks guys I have yet to see 1200. I'm just concerned my old truck would hit 1200 real easy. The temp I see now seem low but boost comes up fast maybe that has to do with the lower temps.
bridleman
Oct 19, 2008 02:11 PM
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
