Easiest/Cheapest DPF/EGR Delete?
Ok, so I don't want to go ***** out like I did on my last 6.7, so what is a easy cheap way to remove the dpf and egr?
I know you can buy just a 4" pipe DPF delete section for less than $200, but what about tuning?
I'm not interested in adding power, I just want to turn off the regen and disable the EGR...
Any help?
-Thanks-
Any help?
-Thanks-
Any help?
-Thanks-
Any help?
-Thanks-
I have only ran the Smarty on SW1 and it feels very lively. The biggest difference is improvement in fuel economy.
My guess is make your own delete pipe, or have a muffler shop fab one (leave the upper cat & downpipe in-place)= $0 to $50
Smarty JR = $500, some places less.
Total with shipping/tax/whatever < $600.
No gauges should be needed if you leave it at stock power, you can add them later anyway as your budget permits.
And no, I haven't tried the above configuration yet- but I am sorely tempted to.
Build you own delete pipe, I just used a left over chunk of 4in exhaust. Install resistors in place of the egt's probes.
Look around there are cheap dpf foulers out there. There is no need for a tuner any more.
I just did mine last month. I got a delete pipe, boost and pyro guages, pillar pod and a Smrty Jr ME. Everything was $1,030. Call the DTR store and Lary will set you up.
But you'll get a CEL unless you run the H&S or Smarty, right? I assume the original poster doesn't want to live with that, nor the potential of reduced power from disconnecting the EGR.
The H&S has the best code free delete system going but that costs money.
I know they make a JR, but I'd rather have the s67me box.
king cotton
Nov 24, 2010 10:33 PM
Strong05
21
Dec 22, 2009 12:14 AM
Red3quarter
Nov 8, 2008 04:11 PM
parafirediesel
18
Oct 22, 2008 01:02 PM
CalypsoCowboy
14
Sep 1, 2008 04:38 PM
