Dually tire help
Old Dec 20, 2013 | 10:21 AM
91.5 beater's Avatar
Dually tire help
What is the largest tire i can go with on my dually without running spacers in the rear?
Old Dec 25, 2013 | 09:09 AM
dragtruck1965's Avatar
On the 2012 we have put 26570r17 on them it gives you about 1/2 inch between tires at 70 psi.
Old Dec 27, 2013 | 09:48 AM
Monstermog's Avatar
I have a 2010...using 245 70r19.5 no spacers.
Old Dec 27, 2013 | 04:02 PM
98whitelightnin's Avatar
255/80/17 should fit with no spacers, but tire options are limited.
Old Jan 20, 2014 | 01:20 PM
cbrahs's Avatar
I run the BFG KM2 on mine. no issues. Only thing I did was level the front but didn't need to do that either and do not have issues in rear with tire spacing
Old Jan 20, 2014 | 08:04 PM
DWeiler's Avatar
Plenty of space between the dual with these plus 3000LBS in the bed full of gravel many times .I run the KM'2 on mine(255-80-R17)----coming up on 48,000miles of mostly hi-way driving with proper tire rotation,50PSI in the rear/55PSI front.I will buy again just for the fact that you do not need a spacer(I have Fred's spacer's sitting here unused just in case i want to step it up to Toyo's M/T 315/70/17 later on)I was just at Costco today kicking prices for the KM2's---up here in Canada things are a bit more $$$$ than USA-----best price so far is 279.00 a tire plus tax+15 to mount/balance.I will get another 5-7000 miles---so probable fall 2014 before i replace-----PS--- up here they are on back order until further notice.Cheers-DW
Bobcat698
Sep 12, 2006 08:36 AM
Mcmopar
Feb 10, 2006 08:25 PM
CTD NUT
Sep 12, 2005 04:40 PM
RobG
Sep 5, 2003 09:13 AM
patriot pearl blue
Dec 9, 2002 08:53 AM
