Camshaft Time
Old Apr 11, 2021 | 11:17 PM
Moparriggan1's Avatar
Camshaft Time
Anyone using Hamilton cams 178 208 cam in a 6.7? Thinking of replacing stock cam with a hamilton..any suggestions....yea neh...
Old Nov 11, 2024 | 07:38 AM
NIOMARVIN83's Avatar
The Hamilton 178/208 cam is a solid upgrade for the 6.7, especially if you want better low-end torque and improved airflow. Here’s what to consider:
Better Low-End Power: The 178/208 cam is known to boost low-end power, which is helpful for towing and daily driving. Many people notice stronger throttle response and smoother power delivery with this cam.
Stock Components: It works well with mostly stock setups, so you don’t need a lot of extra upgrades to make it work. But make sure you have good valve springs to handle the cam’s profile.
Fuel and Airflow Upgrades: To get the most out of it, some people add a bit more fuel or airflow. It’s not required, but it can help you see more benefits from the cam.
Tune Adjustment: You might need a slight tune adjustment to get the best results with the cam.
Overall, the 178/208 is popular and usually works well on a 6.7 if you’re looking for a step up from stock.
CTD2001
Sep 11, 2006 10:29 PM
johnsjas
Jan 27, 2006 07:38 PM
nascar mark
Nov 14, 2002 01:29 PM
1ST GEN.
Nov 12, 2002 08:03 PM
