4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
tranfer case oil
Old May 5, 2016 | 07:28 PM
mikey59's Avatar
tranfer case oil
what kind of lube are what weight goes in the transfer case does any one know ???
Old May 5, 2016 | 08:00 PM
Busboy's Avatar
atf
Old May 6, 2016 | 07:09 PM
gsbrockman's Avatar
Since your signature is not filled in, and you did not identify your truck, it's hard to say.
Old May 6, 2016 | 07:26 PM
mikey59's Avatar
trans fer case lube
sorry I have a 2012 2500 big horn 6.7 . been dig-gen as long as the atf is +4 are equivalent. will that work?
Old May 6, 2016 | 08:10 PM
gsbrockman's Avatar
Since it's a 2012, ATF+4 should be the correct fill.
The 2013 & newer trucks use a BW44-44 fluid....68089195AA.
Old May 7, 2016 | 08:36 AM
1-2-3's Avatar
Just a plain ole guy
Do you fill them with the transmission since it is attached or do they drain and fill separately?
Old May 7, 2016 | 10:11 AM
gsbrockman's Avatar
Two separate systems, and two separate reservoirs. One word of advice----when doing a transfer case service, always make sure one can remove the FILL plug prior to removing the DRAIN plug.
Old May 8, 2016 | 05:39 PM
mikey59's Avatar
thank's for the advise
got my transfer case lube changed and my signature filled in as well
Checkmate
Mar 5, 2005 08:36 PM
Sonny
Feb 7, 2005 10:51 PM
garthed
Feb 3, 2005 10:38 PM
sdgunslinger
Dec 23, 2002 12:27 AM
