Stalled out and won't start
My 2010 recently started cutting out like it wasn't getting fuel. I've changed the fuel filter. The old was grey, it was changed about 1500 miles previous. Every time it starts to cut out it goes to a spartic idle and I have to disconnect the batteries to reset everything. Until now it would fire back up. Now it just sits there and cranks. Anyone have any thoughts
Is it cold out, could the fuel have gelled or be contaminated? If you idle the truck lots have you ever cleaned the grid heaters or the intake temp/pressure sensor? Is the check engine light on if so are there any codes?
It's not that cold out. The first five winters this truck has been in were brutal and it only gelled up once and that's when it got to 53 below with out the wind chill. It's showing codes for fuel pressure I believe. I don't usually idle the truck very much. Until this year I didn't drive the truck in the winter time so it didn't sit and idle very much for that. There is only 65000 miles on the truck.
Vintage Empire
09-18-2007 09:43 PM
seanvu1
07-11-2004 03:48 PM
