4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
HELP ASAP loosing coolant! No leaks! 2014 6.7
Old Jan 7, 2016 | 10:25 PM
Cris Moldovan's Avatar
Hey guys! I'm new and desperate for an answer. My 2014 3500 6.7L is loosing coolant and have no idea where its going. I noticed a little hole on the top radiator hose last week. Changed it, still loosing coolant every 45min -1 hr drive. Installed a new water pump as someone said might be the cause. Not the problem. Temp jumps between 188-210 even in cruise Thermostat? Thanks
Old Jan 8, 2016 | 12:17 PM
Busboy's Avatar
I replied to your other post before seeing this one where you have already changed the pump. The ERG coolers have been known to leak coolant. If you are sure that the system is full when you've filled it I suggest do a sniff test of the exhaust with an exhaust gas analyzer, this will show if there is coolant in the exhaust from either a blown head gasket or the egr cooler leaking.
Old Jan 19, 2016 | 09:19 AM
Beast2B's Avatar
2014 isn't under warranty?
BobQ
36
Jan 24, 2018 09:38 PM
rammike
Sep 6, 2012 10:54 AM
abchoppers
Jan 26, 2011 05:38 AM
archer39
Sep 14, 2010 04:32 PM
Goalie990
Oct 29, 2007 11:45 AM
