4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
lightening bolt on dash
Old Jun 27, 2013 | 06:09 PM
mrugg's Avatar
It only happened once on my 2012 2500. It came on I stopped the truck shut it off then started it back up and the light went out.
Old Jun 27, 2013 | 09:08 PM
XLR8's Avatar
That 'lightning bolt' light is the ETC...Electronic Throttle Control.
Part of the foot throttle...I found this quick 'reset' info. If it continues to happen frequently you will need to replace the sensor ...part of the foot throttle assembly.
'Place you vehicle in the run position without starting engine and depress the gas(foot) pedal and release all in 2 seconds (1 down and 1 up). You should hear a confirmation "ding" if done correctly and you have now reset the sensor to know when you have open throttle.'
Hopefully this clears it and resets...let us know!
Old Jun 27, 2013 | 09:47 PM
mrugg's Avatar
XLR8 yes and thank you. It only did it once.
Old Jul 20, 2013 | 08:06 PM
Rollin'_Coal's Avatar
My truck is a '12 3500 and has the g56 manual trans and did this. I was driving with my foot on the gas and tried to drag the brakes a little with my left foot to clear up a dust squeak and the throttle slammed shut after a few seconds and gave a red lightning bolt. Is it possible that you were hitting both pedals? I've done it a few times now and it does it every time.
Old Jul 20, 2013 | 09:18 PM
mrugg's Avatar
Rollin'coal thanks. It hasn't come on since that one time.
Old Jul 21, 2013 | 11:56 AM
Busboy's Avatar
I always drive with both feet manual or auto and have never had it come up.
Old Jul 21, 2013 | 04:47 PM
Driving with both feet is one thing, do you press the brake and gas at the same time very often? Give it a try and see if it happens?
Old Jul 21, 2013 | 05:01 PM
Busboy's Avatar
Yes I do especially when maneuvering in close quarters with a trailer hooked I use both all the time almost every day lately, I find the torque converter just not always predictable enough so I'm using it more like a clutch I can control. I just thought..I am using a H&S mini so perhaps that's why.
Old Jul 24, 2013 | 10:46 AM
Beast2B's Avatar
or possibly speed has something to do with it. at or near idle it may be acceptable, but at road speeds it may not like it!
Old Jul 24, 2013 | 10:59 AM
I just confirmed this. At idle or rolling slowly it doesn't do it, if you are on the gas and drag the brakes while driving it slams shut, power goes to near zero, loud unhappy turbo bark and lightning bolt. Probably not gonna do that on purpose any more. But now we know for sure!
Old Sep 2, 2013 | 04:58 PM
Timothy Jewell's Avatar
WOW!!! guess you should not Drive Auto trans with two feet? Second foot left foot is for a clutch, no clutch? no need for left foot!
FordTrax
Apr 18, 2014 08:47 PM
NoSparkplugs
17
May 17, 2009 10:36 PM
rammike
Aug 7, 2007 12:34 PM
Lurch519
Jul 9, 2006 11:49 AM
