4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
incorrect dip stick 2011 trucks
Old Mar 30, 2011 | 09:03 AM
cbrahs's Avatar
I have not checked mine but was cruising around chrysler and found this bulletin. fingered I would let everyone know. better safe than sorry
SUBJECT:
Incorrect Engine Oil Level Indicator
OVERVIEW:
This bulletin involves inspecting the engine oil level indicator and replacing it if found to
have an incorrect indicator end.
MODELS:
2011 DJ/D2 Ram 2500/3500 Pickup
2011 DD/DP Ram 3500/4500/5500 Cab Chassis
NOTE: This service bulletin applies only to vehicles equipped with the 6.7L
Cummins Turbo Diesel engine (Sales Code ETJ).
DISCUSSION:
6.7L Cummins Turbo Diesel engines are equipped with an engine oil level indicator that
identify a “Safe” region on the end of the indicator. Some vehicles were equipped with an
engine oil level indicator end that had “Add, Cold, Hot, and Do Not Add” increments on the
end. These engine oil level indicators will need to be replaced.
SYMPTOM/CONDITION:
Customers may state that their engine oil level indicator end has “Add, Cold, Hot, and Do
Not Add” when the Owner's Information indicates that it should have a “Safe” increment on
DIAGNOSIS:
Inspect the engine oil level indicator. If the engine oil level indicator has a “Safe” region on
it, no further action is necessary. If the engine oil level indicator has increments indicating
“Add, Cold, Hot, and Do Not Add,” replace it.
Old Mar 30, 2011 | 09:45 AM
redlineguy's Avatar
Thanks, Mine is good.
Old Mar 30, 2011 | 06:50 PM
Blake Clark's Avatar
Thanks Chris.
Mine is the proper one.
LJTyre
May 30, 2006 07:30 PM
Nimrod
17
Jan 12, 2004 09:40 AM
dodgediesel4x4
Dec 18, 2003 08:36 PM
Cowhand
Aug 26, 2003 01:33 PM
fat_dad54
13
Feb 15, 2003 12:09 PM
