Fuel filtration
i think the cost is the fuel heater. looking at the parts breakdown for that kit, it comes with a updated fuel pump/canister, all lines, harness, filter head, heater, filter etc.
I'm just going to swap out injectors every year. I have a spare set of injectors. The set I pull out, I will send in to get cleaned. At least that way you'll still have warranty. Dodge gets bitchy if you throw in extra filters or aftermarket fuel system, you take away their cash cow.
on the 6.7 you can't just swap injectors (unless you have a witech) because the serial numbers of the injector is programmed into the ECM. truck won't run. the days of being able to swap an injector from 1 hole to another for diagnosing are gone. I have been told by my local dealer, more filtration is good and they support it.
I get a pretty decent deal on getting injectors done up
My local dealership have issues with non stock tires, so forget anything else.
easinc
22
Mar 31, 2011 11:22 PM
MikeyB
Mar 6, 2005 09:23 PM
brillmtb
Jun 6, 2003 07:02 PM
