4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Front U-joints bad?
Old Feb 10, 2017 | 07:29 AM
xp8103's Avatar
Front U-joints bad?
My 11 has 73k on it of relatively moderate use and virtually no HD off roading. Of late, I've felt a slight "hitch" in the steering wheel while in 2WD in a low speed turn. And watching the wheel return to center I can see the hitch. Yesterday we had a n'or easter and I was in 4 high while driving home and the wheel felt much like running in 4wd while on pavement with the steering wheel really rocking back and forth, even when only turned about 1/4 from center. I'm going to say that my front u-joints need to be replaced.
Other opinions?
Old Feb 10, 2017 | 09:51 AM
tobyw's Avatar
I don't know if that's your problem or not, but I will say that I recently helped a buddy change the passenger side u-joint on his 2011 with about 60k miles after experiencing similar issues. We pulled it apart and found nothing but dust inside the bearing caps... It looked like it had been out in the desert for 30 years
Old Feb 10, 2017 | 09:53 AM
xp8103's Avatar
What kind of a job was it to pull and replace?
Old Feb 10, 2017 | 07:20 PM
Busboy's Avatar
I just wonder if you ever lubed the front drive shaft like it says on the sticker under the hood? I often wonder if it makes a difference.
Old Feb 11, 2017 | 05:39 AM
xp8103's Avatar
It's been dealer serviced since new. Not that that means anything. But it sounds like 60-80k miles on ujoints today is about the norm. I never changed them out in my 01.5 2500 that I sold in 2011 with 160k on it.
Old Feb 11, 2017 | 10:37 AM
Busboy's Avatar
I must be getting old or something, After re reading your post I see you are not talking about the front drive shaft ujoints.
Old Feb 13, 2017 | 10:23 AM
tobyw's Avatar
Pulling the shaft didn't take long at all. Getting that U-joint out of there was an ordeal, though. We ended up having to cut the trunnion and only then were we finally able to get the caps to push through the ears. I took some emery cloth to the inside bore of the ears and the new U-joint went in without issue. Probably a two hour job start to finish with a couple frosty beverage breaks.
Old Feb 13, 2017 | 05:33 PM
xp8103's Avatar
hahhahahaahahahahahaha
Old Feb 14, 2017 | 12:44 PM
Busboy's Avatar
Sorry you lost me? I've read the entire thread 3 times now and I'm still unsure which universal joints you are talking about, the hubs or the front drive shaft.
The words "passenger side ujoint" made me think you were talking about the ujoints at the hubs especially after you quoted tobyw.
Old Feb 14, 2017 | 01:06 PM
xp8103's Avatar
Yes, then I apologize. I am referring to the front axle u-joints.
Old Feb 14, 2017 | 07:40 PM
Busboy's Avatar
No worries, I think we are all here to help each other and share what knowledge we have about our trucks.
fatpete
15
Nov 28, 2010 10:13 PM
jiggerman78
May 2, 2009 06:38 AM
DF5152
Mar 19, 2009 05:32 PM
Joe Diesel
23
Mar 25, 2008 07:39 AM
Lost Texan
Oct 23, 2006 11:10 PM
