4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Front Differential Question
Old Dec 15, 2012 | 08:25 AM
New2Diesel's Avatar
"Gomer Pyle"
This weekend I installed the MagHytec Rear Diff Cover with sight glass and added new fluid. My questions is on the Front Diff. The fluid change is required every 30K miles. I'm assuming the front diff does not even rotate unless the 4WD is engaged? If that is the case, why change the fluid every 30K miles in the Front Diff?
Any advice?
Old Dec 15, 2012 | 08:54 AM
tpollon2's Avatar
It does rotate. Is there any part of your front end Physically hitting your New diff cover? On my 2010 it hit in 2 spots. Looking at the diff cover, top right and middle left side.
Old Dec 15, 2012 | 11:52 AM
New2Diesel's Avatar
"Gomer Pyle"
No, the brand new cover that Mag Hytec engineered fixed the rubbing problem. Plus, with my modded factory suspension it clears without any issues.
Old Dec 16, 2012 | 02:49 PM
tpollon2's Avatar
I actually had both generations with front end 1 inch lift. They both fit horrible. Now have AFE and it hits as well, not as bad though. 1 Litre less capacity than the Mag. Cant win LOL
Old Dec 16, 2012 | 08:54 PM
6.7L MegaCab's Avatar
As mentioned, it does rotate, now the question about it needing to be changed every 30k can really only be answered by sending a sample to a reputable lab such as Black Stone or Oil Analyzers, Inc. I don't trust oem oil so I changed both front/rear gear oil around 15k miles when I installed the Mag-Hytec cover on the rear.
Sent from my DROID X2 using Tapatalk 2
Old Dec 17, 2012 | 02:43 PM
SOhappy's Avatar
I would definitely do it the first time at 30k, as the factory oil gets really bad as things wear-in. After that, it depends...if you're going off-road in the mud/water/deep snow or launching boats I'd sure change it often. Otherwise you might could get away with every 45k-60k.
Old Dec 17, 2012 | 06:36 PM
New2Diesel's Avatar
"Gomer Pyle"
Well, I'm about the least off road guy on the planet. My truck might have been in 2" of water and thats about it. Although I do some pretty mean burn-outs from time to time. My truck currently has 23K miles on it and I am already on my 4th set of tires. It is amazing what this thing will do to some rubber.
As far as pics, as soon as it stops raining here in NC I'll post some for you.
gsdog1
Jan 30, 2004 07:58 PM
Tartarus
Jan 23, 2004 07:24 PM
gotagoat
Dec 7, 2003 01:06 PM
BAD HABIT
Nov 2, 2003 09:03 AM
BADodge2003
Aug 6, 2003 09:43 PM
