Front differential lube change?
Old Jan 22, 2004 | 09:56 PM
Tartarus's Avatar
Any advice on changing the front differential lube? I was going to swap it out for synthetic and forget about it -- take the old fluid out with a suction pump. But I realize now that I've got the late '02 front dif -- always spinning. I'm wondering whether I ought to open up the case and clean it out. Seems like a waste, though, other trucks I've owned had them last forever, with 150K + clean oil.
Old Jan 23, 2004 | 06:36 AM
Commatoze's Avatar
I changed mine late last summer, and was surprised how clear the fluid was after 50,000 miles. I too have the "late" axle up front. I guess without a load, there is little gear wear.
Old Jan 23, 2004 | 09:23 AM
amartinson's Avatar
My personal opinion is to change the fluid on a regular basis either according to the manual or to personal preference. The cost of the fluids is not that much even when using synthetic.
I've never heard of anybody with a broken part say " If I had only not changed the fluid so much."
Just my $.02 worth.
Old Jan 23, 2004 | 12:37 PM
Dieseldude4x4's Avatar
Good one..............
One guy here at work makes fun of me because I change the power steering fluid and brake fluid every year too. Same thing.
Old Jan 23, 2004 | 02:01 PM
Commatoze's Avatar
I agree. But the front diff can be a pain with the tie rod so close to the cover. I popped the rod end off the spindle and swung the rod out of the way a little. And I always feel resealing the cover is a bit of a crapshoot too. I had a bad seal using Permatex, had a few drips so had to break it off and try again. This time it worked using the MOPAR RTV.
Old Jan 23, 2004 | 02:10 PM
amartinson's Avatar
Same here. That does get expensive if you have to dump out $30 worth of synthetic gear lube because of a small leak. I did the same thing, got the MOPAR RTV, no more leaks.
Old Jan 23, 2004 | 03:52 PM
TPilaske's Avatar
The Mag-Hytec cover on the front makes it real easy to change!
Hey Tom, what ever happened with your cover anyway??
Tony
Old Jan 23, 2004 | 04:16 PM
HOHN's Avatar
I can't use the Mag-hytec because I have a DT track bar, so I just popped off the diff cover and used RTV to button it back up.
The Redline 75w-90 is a GREAT gear oil.
I also have the late '02 without CAD.
I recommend that you slightly overfill the diff to ensure that the axle tubes have enough. Foaming is not an issue with a decent lube, and it really helps keep the axle seals from drying out.
Justin
Old Jan 23, 2004 | 04:17 PM
HOHN's Avatar
btw-- did my first diff change @9000 miles. I have 24K now.
Old Jan 23, 2004 | 05:14 PM
gsdog1's Avatar
Justin:
I have a SJ trac bar up front. Will anything but a stock trac bar prohibit the use of the Mag-hytec on the front?
Thanks!
Matt
Old Jan 23, 2004 | 06:18 PM
Tartarus's Avatar
I'm probably lazy, but I decided to compromise -- drove the truck to "mix up" the front dif oil, suctioned it out with a pump, and replaced it with Redline 75w-90. I'll do it again every other year.
Old Jan 23, 2004 | 07:21 PM
Commatoze's Avatar
Hey, it's better than not doing it at all!
Old Jan 23, 2004 | 07:24 PM
Commatoze's Avatar
Originally posted by gsdog1
Justin:
Thanks!
Matt
As far as I know, Yes. They look really but unfortunately I'm having vented cover issues that Mag-Hytec has not resolved yet. Until they do, I'm forced to run the stock cover. It only affects late 02's
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
markm4
Jul 29, 2007 11:16 AM
gnuesse
Sep 17, 2006 06:48 PM
cummins1
15
Dec 27, 2002 07:45 AM
