4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Anyone know the gear ratios in the 6sp manual?
Old Jan 21, 2010 | 12:21 PM
truckin-on's Avatar
Just ordered a 2010 3500 Laramie SRW w/ a stick and 3.73s. Now I'm wondering if I really should have stayed with the 3.42's. Anyone have the ratios in the box? I remember seeing the auto ratios, but never the stick. I assume they are not the same as the auto.
-truckin-on
Old Jan 21, 2010 | 02:02 PM
redruM Hauler's Avatar
-truckin-on
1st - 6.29 -
2nd - 3.48 -
3rd - 2.10 -
4th - 1.38 -
5th - 1.00 -
6th - 0.79 -
Old Jan 21, 2010 | 02:19 PM
ridofpwrstroke's Avatar
The ratio for sixth was changed i think late 07. I think it is now .74 for sixth gear. It depends if you ever plan on running 35's. If you do, keep the 3.73's or if you are going to tow heavy. You are going to be real close to 2000 rpms at 68 I believe. With the .79 in my truck, I am at 63mph at 2k.
Old Jan 21, 2010 | 03:49 PM
truckin-on's Avatar
What is the sweet-spot RPM-wise for the Cummins running light vs. towing? I haul a fairly decent sized 32' 5th wheel, probably go nearly 10k fully loaded.
My current truck is a 7.4l big-block Chevy w/ a 5-sp OD manual and 4.11s in it, and I'm trying to sort out what would work best for me with the new CTD.
It looks like Dodge rates the 3.73 for 2k more GCVW and trailer weight over the 3.42 gears. Don't totally understand this, as I would assume you would just pull in 5th rather than 6th, which would be a stronger gear anyway as it's straight-through 1.0.
-truckin-on
Old Jan 21, 2010 | 08:45 PM
Spooler's Avatar
Get the 3.73 gears pulling that heavy and I assume the truck will be a 2wd. Backing up and starting off will stink with 3.42 gears. 3.42 and pulling in 5th i beat you will loose MPG. The sweet spot for me towing is 1800 to 2200 Rpm.
Old Jan 21, 2010 | 10:15 PM
truckin-on's Avatar
OK - thanks. I think I'll leave it with 3.73's. Should be enough cogs to choose from hopefully! It's a 4WD by the way...
Old Jan 22, 2010 | 06:55 AM
MikeyB's Avatar
The latest version of the G56 should have a .74 OD.
MikeyB
Old Jan 22, 2010 | 08:30 AM
AH64ID's Avatar
Originally Posted by redruM Hauler
1st - 6.29 -
2nd - 3.48 -
3rd - 2.10 -
4th - 1.38 -
5th - 1.00 -
6th - 0.79 -
That is the AD ratio. It was changed in the end of CY06 (Early MY07).
The current AE ratio's are:
Gear Ratios:
First: 5.94
Second: 3.28
Third: 1.98
Fourth: 1.30
Fifth: 1.00
Sixth: 0.74
Reverse: 5.42
Old Jan 27, 2010 | 02:13 AM
It depends on how many times you tow a year and how many times you drive it empty. I would go with the 3.42's if you tow down roads that have a 65 or 70 mph speed limit even with a 10k load. The 6.7 has great low end even compared to my 5.9. If you are going to tow mostly at 55mph or 60 and tow alot, I would opt for the 3.73's. You wont notice a huge difference between the two gears backing up or taking off.
JonM
Jul 24, 2012 12:40 PM
jerry61
Aug 21, 2007 12:02 PM
mr. ed
32
May 31, 2007 05:20 PM
vzarich
Apr 2, 2006 06:34 PM
ade's ram
16
Mar 14, 2005 02:01 PM
