4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
Tachometer on Non Ic 1st Gen?
Old 10-25-2016, 11:22 AM
TruckYou's Avatar
Iv been doing a bunch of research over the last couple days. My truck is a 91 non Ic. I found lots of information on how to put a tach in a 91.5-93 (The plug under the dash)... How about the earlier 1st gens?
Old 10-26-2016, 12:02 AM
1320Fastback's Avatar
You could get a magnetic pickup tach kit or wire it to a stator post in the alternator and get a electric tach with cylinder adjustment switch.
Old 10-26-2016, 01:18 AM
TruckYou's Avatar
Very cool. I just did some research. this isn't something I have any experience with. I did some reading on the electronic tachometers, that you basically wire to the alternator, 12vdc, and ground. Is that basically the same deal people do on the 91-93 trucks with the plug under the driverside, except there's is all right there in one location?
Would something like this work?
http://www.starmarinedepot.com/faria-euro-black-4"-tachometer---4,000-rpm-(diesel---magnetic-pick-up)/pzz26904.html?gclid=Cj0KEQjwhbzABRDHw_i4q6fXoLIBEi QANZKGW2LkyEbaPoOqwjtGwl-t1zNRY3F1g50S9SXISuTfnpwaArlh8P8HAQ
Old 10-26-2016, 07:49 AM
The IC trucks I think pick up there tach signal off the crank sensor but I could be wrong.
That tach would work but does not say if it comes with the mag pickup or not.
Old 10-26-2016, 10:32 AM
TruckYou's Avatar
I see the magnetic pick ups on google, which a lot of guys run of the Isspro R5503 tachs, my only problem with that is I can't fathom spending $200+ on this project
I found a YouTube video of someone putting a tach on what looks like a 1st gen, ic Cummins I'll post it below. In the video he simply wires to a Switched (keyed) 12v supply, ground, and to a stator on the alternator. Is there any reason this cannot be done on the non ic trucks?
Would I be able to purchase a tachometer like this at a local parts store?
I have no experience with installing gauges on these old trucks, so please don't mind me if I'm asking stupid questions.
92GhostRyder
09-16-2018 12:02 PM
BRUISER
02-02-2015 11:25 AM
77machomopar
07-15-2009 04:56 AM
pulltilbroke
04-10-2009 02:08 PM
cethane
12-16-2002 11:07 AM
Quick Reply: Tachometer on Non Ic 1st Gen?
