Wiring through firewall?
Old Mar 7, 2007 | 01:49 AM
carl20320's Avatar
Where have you found a good spot to run wires through the firewall. I jsut finished hooling up the reverse switched portion of my KC Backup lights. I want to get the switch hooked up soon. This afternoon, I looked from the engine compartment but didn't really see what I thought would be a good spot.
TIA
Carl
Old Mar 7, 2007 | 02:00 AM
53 willys's Avatar
since you have a auto trans there should be a hole where the clutch pedal would go through the firewall that would be the easiest spot, I would think.
Old Mar 7, 2007 | 04:53 AM
own1bigtruck's Avatar
Thats what I did. Used a 1" hole saw to cut through the plate, then put a rubber grommet in to prevent chafing of the wires. Will seal it off with silicone once im done running stuff through there
Old Mar 7, 2007 | 06:36 AM
Jus Cruisin's Avatar
There is already a big hole that the hood release goes thru. Just cut a hole in the grommet and then silicone it once the wire is run.
Old Mar 7, 2007 | 06:54 AM
RamWheelsBy4's Avatar
I also run all my gauge, controller and other wiring through a hole drilled in the clutch hole cover.
Old Mar 7, 2007 | 07:43 AM
yup thats about what mine looks like, other than I didnt get all fancy with the corrugated tube. But im not done running wires through there yet either!
Old Mar 7, 2007 | 08:27 AM
carl20320's Avatar
Thanks guys. I will be able to do that one as soon as I get another break in the rain.
Carl
Old Mar 7, 2007 | 10:10 AM
ptgarcia's Avatar
I just put a slit in the grommet for the hood release and ran all my wires through there. I have harnesses for my light switches, exhaust brake switch, Commander, and Xzillaraider all run through the same spot.
Old Mar 7, 2007 | 04:28 PM
rjm022's Avatar
i also use the clutch hole cover. i drilled a 1 1/2 hole. i am out of space there now!! need to find another spot to rum wires for the our lights i will be putting on in the spring!
Old Mar 7, 2007 | 05:43 PM
Well I have stuffed mine with a lot of other things since the picture was taken. I had to take a dremel tool and enlarge the opening for the last gauge wiring harness.
DuaneWKKC
Feb 16, 2008 02:44 PM
michael_b8
Aug 31, 2007 07:46 PM
johnontheroad
Jun 13, 2007 09:50 AM
clarson80
Feb 1, 2007 04:27 PM
hipsi
May 1, 2005 09:31 AM
