View Poll Results: What have been your A/C problems ?
Blend door problem ?
39
30.47%
Recirculating door problem ?
41
32.03%
Compressor / Coil problem ?
44
34.38%
Ignition switch / electrical problem ?
5.47%
Head unit controller problem ?
6.25%
Other problem ?
26
20.31%
No problems at all ?
27
21.09%
Multiple Choice Poll. Voters: 128. You may not vote on this poll
Who has had A/C problems ??????
One of mine is an 05 with 100,000+ miles. Coil failure and electrical problem.
The other 05 has 45,000 miles. Head unit controller quit working. Still haven't figured out either one.
David
David
yep, mine crap on a stick. I don't know on an average day if mine will actually blow or not. I have to tap on the motor to get it started. Been "fixed" by the dealer at least 8 times and still doesn't cool. One thing that dodge has never done right...
110k on my 06 A/C problems started right out of the chute. Recirc door fell out about 1 day after warranty. I have had a new compressor installed @ 80k
(2 yrs old) 2 leaks fixed and the tipm had to be reset. Right now I have the "manifold hose assy" leak... the part by the way, is on national backorder
I guess a lot of these pipes must be failing.
I think there should be a class action lawsuit....
Had issues with the evap freezing up, put the gauges on it to see what was up, low charge. Added some refrigerant and all is well, just took a trip out to Cedar Point, Oh no problems at all. Oh....03 with 59k....
06 with 42000 miles, a/c currently not working... leaking evap and condenser, as per dealers diagnosis, who knows what else is actually wrong with it... and these repairs are quoted $1800. No A/C SUCKS!!!
I blocked the outside/recirc door in the recirc positon til I have time to fix it. I don't get air to the defrost or floor and the passenger side is warmer so I know there are several problems. Craig
ignition sw caused blower to stop working bout 30k mi on an 04.5 laramie
w dual climate control
and the pass side blows warmer more often than not
(if i drive a while it eventually gets cooler and i also slide tstat back and forth several times to get pass side cooler)
...not sure what`s going on with mine yet. It cools when it wants to , sometimes it feels like it`s making ice cubes
, other times it`s blowing like the A/C is off , and just the fan is blowing
...`04.5 Laramie w/59K miles
