Where do you put the floor jack.
Old Aug 6, 2004 | 02:12 PM
fanofthewolf's Avatar
I rotate my own tires and was wondering what points you lift from. I have one floor jack and use a jackstand so one tire is always off once I get started.
I think I recall the manual only showing points for the jack in the truck.
Old Aug 6, 2004 | 02:18 PM
Jeff in TD's Avatar
Under the axel, to the outside, at least on a 4x4
Old Aug 6, 2004 | 02:39 PM
The rear is no problem. Mine is a 2WD and there is very little choice in the front.
Old Aug 6, 2004 | 03:35 PM
Captain's Avatar
I use a peice of 2x4 and a 2x2 on top of it to get at the front axel. Very close to the wheel as always. the father in you go the more strees on the axel tube and I always worry about ripping it out of the pumpkin. Lots of weight on thies things.
Old Aug 6, 2004 | 06:16 PM
SuperGewl's Avatar
Get a matching spare wheel and do the 5 tier rotation. That way when it's time to buy new tires if you change brands the spare will be of the same type because you will have to buy 5.
Yes it does cost more but then the tires will go longer about 25% longer.
Shorts
Apr 18, 2012 08:01 PM
mkinla
Apr 17, 2011 08:06 PM
usmc2311
Feb 17, 2006 11:26 PM
eswartz
Mar 16, 2005 10:40 PM
phox_mulder
Mar 17, 2003 10:32 AM
