water leak in cab
2006 Mega cab one day it was raining very hard and when I got in my truck there was water running out of the plug where the grab handle is on the windshield pillar, i played with the power moonroof it may not have been closed all the way, still not sure?
There was a TSB on the '03 and I went ahead and replaced mine with clear aftermarket covers. Looked much better but the **** thing still leaks. I'm going to try and use a sealer to see if that helps. My leak is from the cab light right above the latch for the sun visor on pass side.
My clearance lights had little plastic washers under the screws that were brittle and cracked. I had some leftover nylon washers from a metal storage building assembly. They fit perfect. Hasn't rained enough to see if it is fixed though.
You might also want to check the glue around your windows. There is a TSB on the 03-04 trucks (http://dodgeram.info/tsb/2004/23-003-04.htm)
Shawn
Shawn
RamWheelsBy4
Apr 11, 2007 04:43 PM
243
25
Aug 6, 2005 11:49 PM
