Under Hood Light
Old Feb 14, 2007 | 08:34 PM
Rockram's Avatar
I found a light on a retractable cord from a cherokee that I'm going to install with a switch. Like the one on the 90 Chev 05HDRAM mentioned.
Old Feb 15, 2007 | 04:35 PM
mizzu's Avatar
hood light
Just got mine today. Easy install, something Dodge should have put in to begin with. Even Geo's come with hood lights, sheesh.
Old Feb 15, 2007 | 04:46 PM
ptgarcia's Avatar
I use a 1,000,000 candlepower spot light I got from Walmart for $10. Plugs into the 12v power port and is even brighter than a Mag-Lite!
Old Feb 16, 2007 | 10:33 AM
mb889's Avatar
RamWheels did you add the factory cup holder light? Can you tell me what the wire connector looked like?
Old Feb 16, 2007 | 01:25 PM
RamWheelsBy4's Avatar
I did add it. It was a while back, so not positive, but on my 04.5 SLT when I pulled off the console cover there was a small white connector to the left side above the cup holder. It was held in place with a rubber/plastic snap in wire connector. I believe that it was only a two wire (black/white) connector, only two wires on the light connector. Plugged them together, snapped the light holder assembly into the slot in the dash above the cup holders and that was it.
Hope that helps more than it confuses you, sometimes my explanations are less than perfect.
Old Feb 16, 2007 | 03:23 PM
mb889's Avatar
Thanks for the info
Old Feb 16, 2007 | 07:15 PM
Fisherguy's Avatar
I had the center of my dash apart as mentioned, only wires I saw there were a couple plugs with about 4 wires in them, I assume they are for the heated seats and power rear slider I don't have.
I know I have wires on the firewall for the under hood light though.
So unless I'm looking in the wrong spot, I wonder if I'll be able to hook up a cup light? Seems weird I'd have some wiring and not the rest..?
Old Feb 16, 2007 | 07:36 PM
mb889's Avatar
Fisherguy thats just what i have in that spot. I went to the dealer to ask them about those wires. He asked for the last nine of my vin and told me that i dont have the wiring for the cup holder light. I know that i do have the wiring for the glove box light and the under hood light.
Old Feb 16, 2007 | 09:13 PM
Fisherguy's Avatar
Hmmm, that makes sense to you?
Old Feb 16, 2007 | 10:55 PM
mb889's Avatar
maybe i didn't have enough "eh" in there.
Old Feb 16, 2007 | 11:16 PM
Fisherguy's Avatar
So what are we to do without a cup light eh?
(stoopid DC!)
Old Feb 17, 2007 | 10:31 AM
gradyjim2003's Avatar
Talking Underhood light
I went to the junkie and got one from an old Chevy. These have the wound pigtails with a magnetic bottom on the light itself. Plus an on/off swith on the unit to boot! And the cost of $10.00 wasn't tough to take haha
Old Sep 22, 2007 | 09:28 PM
btolenti's Avatar
anyone have pics on how to route the underhood light harness. I cant figure it out for the life of me.....
Old Sep 22, 2007 | 11:10 PM
speakle's Avatar
Ha, I had the same problem, this should help.
http://www.dodgeforum.com/m_912494/tm.htm
Old Sep 22, 2007 | 11:54 PM
Pav1973's Avatar
As for the ashtray and or cup holders,I went to advaced auto got a 3 led light strip, about 1in long and had sticky tape on it,pulled the dash apart used a wire tester to find a hot wire that is controlled from the dimmer switch and hooked that up,stuck it uder the cup holders.
See if this pict helps any.
Sounds like alot but it took maybe 10 mins.
They have red,blue,green,white.
My fan speed ***** there are billit and have blue LED's glued in them.
Pav
Fisherguy
Jun 8, 2006 10:07 AM
SolarYellow05
Dec 19, 2005 06:07 AM
Patriot_RAM
15
Sep 16, 2004 04:42 PM
Dodgezilla
Feb 13, 2004 03:40 PM
