Truck had a brain fart
Old Aug 9, 2007 | 10:07 PM
Fire Rescue124's Avatar
today i was haulling my horse trailer empty to pick up a horse. i had just got on the highway and got it up to speed. "75 to 80" and my speedo and Tach dropped down to 0 and my fuel light came on all for just a milli second and everything went back to norm and the truck was running fine it didn't miss or lunge. Anyone know anything about that or had it happen to them? the only code i get is P 0573 which is some high voltage to the brake light. Truck running fine now i pulled about 250 miles after that with two horses so trailer and all about 8-10K with no problem.
Old Aug 10, 2007 | 02:14 AM
TexasCTD's Avatar
Just a guess, but if your lift pump is still stock.........that is usually the culprit on our trucks to cause something like this. I would have it checked out or replaced before it leaves you stranded.
I would go ahead and upgrade it with a GDP or FASS instead of getting the "in-tank" pump.
I don't think the brake light code had anything to do with it. Good luck and let us know what happens.
Old Aug 10, 2007 | 07:50 AM
jrussell's Avatar
Why would the lift pump cause his dash to go haywire like that?
Sounds like an electrical issue somewhere. Since you got a code related to the brake lights I would start by checking the trucks brake lights and the trailer wiring.
Old Aug 10, 2007 | 08:40 AM
53 willys's Avatar
SYMPTOM
P0573-HIGH VOLTAGE DETECTED AT THE BRAKE SWITCH
WHEN MONITORED
While the ignition is on.
POSSIBLE CAUSES
Brake switch shorted to voltage
REPAIR INSTRUCTIONS
BRAKE SWITCH SHORTED TO VOLTAGE
Repair Brake switch shorted to voltage.
sounds like a bad brake switch to me...if the brake lights still work I guess it could have been a fluke????
but I would defiantly check the brake lights
Old Aug 10, 2007 | 11:42 AM
ok about the brakes i had my Lamp out light come on and off a million times one day so i check my lights and found that the drive brake light wouldn't work some times so i look at it and the metal on the bulb looked to be burnt like it was comming in and out of contact so i ben the female prongs in some to make a better connection. so now the brake lights are working fine and the lamp out light has gone. if that was making codes would it go away as soon as it was fixed or do i need to reset something? are the light thing happened before my dash did its thing. do i need to take it to a shop or should i go to Dodge?
Old Aug 10, 2007 | 12:15 PM
TexasCTD's Avatar
You are right, I missed the part about the dash. That's what I get for posting when im tired and half asleep....
Please ignore my previous post and carry on! Thanks JR.
Old Aug 10, 2007 | 01:15 PM
rockdonon's Avatar
I had kinda the same problem with an 04. The dash gauges would go gooffy for just a second, then everything would be OK no codes. After a second time I took it to a dealer and they couldn't find anything. The third time it happened my lift pump died. Got a in/tank retro fit by dealer under emisions warranty. 2 months later gauges went gooffy and turck died in the middle of the desert. Towed to nearest dealer 150 miles. after 1 week at the dealer the truck started. Dealer still couldn't find anything wrong. Drove the truck home and traded it in on an 06.
Old Aug 12, 2007 | 02:35 AM
Owieo's Avatar
Had this happen to my 98.5 a couple times over 2 weeks. Found one of 3 extra wires attached to positive post had been eaten thru with acid. Cleaned posts and replaced wire end about a month ago and haven't had any more trouble. I think that is what caused it.
Good Luck
1967david
Jan 24, 2015 05:46 PM
turbomar
Nov 5, 2009 06:30 PM
ClawHammer
Jul 16, 2004 02:02 PM
BUZZB8Z
Dec 19, 2003 02:12 PM
