Torque specs for shock mounts and front shocks
Old Nov 10, 2009 | 08:06 PM
1985cucv's Avatar
What are the torque specs for the front shocks and shock mounts as well as the tower where the spring fits into? thanks
Old Nov 11, 2009 | 06:01 AM
SAVOY1964's Avatar
NOTE: Upper shock nut must be replaced or use
Mopar Lock ’N Seal or LoctiteT 242 on existing nut.
INSTALLATION
(1) Position the lower retainer and grommet on the
upper stud. Insert the shock absorber through the
spring from engine compartment.
(2) Install the lower bolt and tighten to 135 N·m
(100 ft. lbs.).
(3) Install the upper shock bracket and three nuts.
Tighten nuts to 75 N·m (55 ft. lbs.).
(4) Install upper grommet and retainer. Install
upper shock nut and tighten to 47 N·m (35 ft. lbs).
I beleve this is what you needed.
Old Nov 11, 2009 | 08:14 PM
1985cucv's Avatar
exactly thanks for everything
whosdunit
Jan 11, 2017 01:54 AM
lniemeyer2
Oct 24, 2012 12:11 PM
Bigiron
Mar 26, 2009 11:25 PM
kiszka6911
Aug 2, 2008 08:49 AM
BARTMAN
0
Jun 14, 2006 08:36 PM
