tank vent kit
Old Mar 10, 2007 | 04:26 AM
  #91
Dixie Chopper's Avatar
Originally Posted by 10-9jc
From what I've seen on the "other" forum -
folks are getting 39-40 gallons into a 34-35
gallon tank. [And - very happy!]
But . . .it's a bit of work for the faster fill -or-
an extra 4 gallons.
If you live in Phoenix, you don't park your truck in
the summer sun after a fill-up.
Good point. I'm sure that's part of the reasoning for not using the full capacity of the tank. thermal expansion..........
Old Mar 10, 2007 | 07:08 AM
  #92
moterhead's Avatar
Originally Posted by RocketJohn
It looked like the neck to me...
I can't imagine the engineers would program the light to come on when there was less than a gallon left in the tank... Like I said, I pulled over about 3 miles after the light came on and i filled up with over 30 gallons...
Now are we thinking the tank is actually 40 gallons but fits 34 due to the vent issue?
Actually they program the light to come on a good bit before the tank is anywhere near REALLY empty. Same goes for the DTE showing 0 in the overhead. Somewhere in the owner's manual, there is a good explanation of the percentage of tank capacity at each indicator. "Seems" like I remember something about 8% of capacity when the low fuel light goes on but on a 34 gallon tank that's less than 3 gallons, so it's probably more. Don't have time to look it up right now. I drove my '04 100 miles with the low fuel light on and 50 with DTE showing 0.
Old Mar 10, 2007 | 07:44 AM
  #93
rjm022's Avatar
it is a chrysler tool-part number 700-2010. (that is the one i got) they also had another one for chrysler, part number 700-2096
Old Mar 10, 2007 | 08:05 PM
  #94
Festus's Avatar
I don't have a problem with mine filling right into the neck. They must have done something different at the factory because it takes me 30 sec to top it right to having fuel sit in the neck.
I thought this was one mod I have to do for sure, but have taken it off my list.
Old Mar 12, 2007 | 01:27 AM
  #95
TexasCTD's Avatar
Me and some buddies just installed my Vent Tank mod too along with the mod for the hoses for the barbed fitting on top of the tank. This thing works great. (so does my new GDP Walbro system).
Anyway, after completing this mod...........I probably only had about 2 gallons of diesel in my tank. I let it run VERY VERY low, knowing I had a 5 gallon can available. When it was completed, I poured in the 5 gallon can and drove about 12 miles or so to a town and filled up my truck. 36 + gallons to fill up. So it must hold close to 40 gallons on my long bed truck!!! I filled the fuel right up the brim.
On a different note......our tanks have two plastic barbed fittings for venting on top of the tank. DC just leaves them wide open!! Crud or sand or whatever can get in them and get into your fuel!!!!!!!!! I highly recommend every body put some fuel hose on the fittings and "T" them together and run a line up above your filler neck. I placed a cheapo fuel filter on it too after I went above the filler neck and looped it and dropped it back down a little.
I have to admit, however, my fuel tank was clean as a whistle with 61k on my truck. I still wonder how something hasn't got in those fittings. But if you don't put some hose on them I would think fuel would run out the top of the tank if you did the Vent tank mod and brought fuel up to the filler neck.
Old Mar 12, 2007 | 09:06 AM
  #96
moterhead's Avatar
I've read many posts on the supposedly open barbs on the top of the tank and the suggestions about putting hoses on 'em, etc. I've had Dave Kelley's vent kit on my '04 for years. I have never had any problems with junk getting into the tank nor have I ever seen anything come out of those barbs. If they are open, I'd think that when I fill my tank until fuel is standing in the neck in the summer and the fuel expands, fuel would be forced out those barbs. That has never happened to me.
Old Mar 12, 2007 | 11:33 AM
  #97
Pooter's Avatar
Off hand, do you happen to remember what size the hose was for the two little barbs? I just got my fuel tank vent kit from David Kelly, and I wanted to take care of it at the same time...
Im guessing you also used diesel rated hose too right, for the two small vents?
Old Mar 12, 2007 | 11:39 AM
  #98
bumpytruck's Avatar
Hey stacked,I did mine. The hose is 1/4" I.D. with a tee fitting about 6-7' total and an inline fuel filter.The filter is 5/16" but I heated up my 1/4" hose and slipped it right on. You can do a search on here,its refered to as the roll over vent mod.Oh I used 1/4" fuel line
Old Mar 12, 2007 | 11:44 AM
  #99
Pooter's Avatar
Cool, thanks Bumpy...
I wanted to knock out two birds with one stone while im under there...
Old Mar 12, 2007 | 12:45 PM
  #100
TexasCTD's Avatar
https://www.dieseltruckresource.com/...d.php?t=117209
Stacked, here is another thread about it that I used for gathering parts etc. Pet did a write up with some pics. But since I did the Vent Tank Mod too, I ran the fuel hose up to the filler neck, looped it, tied it up...and pointed the hose with the filter back down. (instead of running it into the frame rail like he suggested)
I ran 1/4'' from the barbed fittings.....into a T...and then ran 5/16'' from the T up to the filler neck/filter.
Old Mar 12, 2007 | 02:02 PM
  #101
Pooter's Avatar
Cool thanks for the link/info
Old May 20, 2007 | 07:54 AM
  #102
tbone's Avatar
Glad to see you got that done. I knew you'd love it.
Old May 20, 2007 | 03:52 PM
  #103
TexasCTD's Avatar
I do!! I have driven about 6000 miles or so since I did it. It sure is nice to go like almost 400 miles now before my tank even hits the half way mark on the fuel gauge!!! Really helps lengthen that cruising range. And now every time I fill up, I know I am adding the exact amount back in that I burned since I can see the fuel in the filler neck.
Old May 20, 2007 | 08:02 PM
  #104
Rod M's Avatar
Just installed one on my '07 Friday. Took a little over an hour. It had about 2 gallons in it and I put in 37 gallons to fill it up. It still took a couple clicks at the pump to get the foam settled, but it filled all the way into the neck and stayed there. Call me happy!
Old May 21, 2007 | 09:02 PM
  #105
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Same Here
Same here my 2007 fills to the neck no problem.....200% better than my '03
