steering gearbox leak
Old Jun 29, 2008 | 02:04 PM
Blue600's Avatar
It is leaking from the bottom shaft to the pitman arm. Is the seal or o-ring replaceable externally or do you have to go into the box? Also does anyone have an exploded view of the box?
Thanks, Les
Old Jun 29, 2008 | 10:59 PM
dozer12216's Avatar
Have to pull steering arm off. It is generally very difficult and requires special puller. You destroy parts when trying to brake loose with hammer. Then lower seal is replacable. Should be readilly avaliable as kit.
Old Jun 30, 2008 | 07:19 AM
Blue600's Avatar
So the seal is accessable without taking the box apart?
Old Jun 30, 2008 | 07:12 PM
Blue600's Avatar
Anyone have an exploded view of the box?
Old Jun 30, 2008 | 09:05 PM
Tobin's Avatar
Make sure the power steering resevoir cap is venting before replacing the seal. After driving pull off the cap and see if it is pressurized as you pull it off.
Tobin
Old Jul 1, 2008 | 07:25 AM
Blue600's Avatar
A clogged cap would make it leak? It is leaking pretty badly.
Old Jul 3, 2008 | 07:18 AM
Blue600's Avatar
Anyone have the torque specs for the pitman arm, steering box to frame and steering shaft to the box?
Thanks
torquefan
Apr 14, 2008 09:24 PM
bryan5791
Jan 8, 2008 02:00 AM
DZLROKET
Aug 13, 2007 09:06 AM
the496rocket
Feb 28, 2007 07:29 AM
DieselJoe
Apr 3, 2006 12:05 PM
