Nitto A/T
Old Jul 1, 2008 | 09:30 PM
Nvisable's Avatar
Nitto A/T
I just put some Nitto Terra Grapplers (285 70 17) on the truck and it's wondering all over the road now. I checked the torque on the lug nuts and checked the tire pressure. Everything seems right.
Any idea's on why it feels so unstable?
Old Jul 1, 2008 | 10:42 PM
ozpall's Avatar
bring em back to the tire store that mounted them and maybe they can balance them again???
Old Jul 1, 2008 | 11:22 PM
cmac's Avatar
had the same problem..... it is a soft tire, soft sidewall and i thought mine wore pretty fast to. hope ya like em
Old Jul 1, 2008 | 11:30 PM
ozpall's Avatar
i had em on my f250 psd and they were pretty good???
Old Jul 2, 2008 | 12:52 AM
nwjetboat's Avatar
I just installed a set of the 285-E's in place of a set of 40K mile BFG's. The ride is smoother, and the truck steers like a dream again. What are you running for air pressure? Empty truck, I run 65 front 55 rear.
Old Jul 2, 2008 | 07:05 AM
MikeyB's Avatar
The tires need to run through a couple of good heat cycles to remove the mold release and to firm up the tread. Takes about 500-1000 miles to do this.
MikeyB
Old Jul 2, 2008 | 09:17 AM
Nvisable's Avatar
The tire pressure is set to the factory setting of 65psi front and 80psi rear. I agree these tire do ride very nice in a straight line. They've really removed a lot of the harshness in the ride. The side to side movement on the other hand feels like the back end is going to break free when I maneuver. It's back at the shop right now. They are going to check the alignment. I don't think that's the problem. I'll post the outcome.
Old Jul 2, 2008 | 11:22 AM
shineboy2's Avatar
I agree. I have 295's... wearing out like crazy! I love the size of 'em, that's the only thing. Not many ppl make 295's.
Old Jul 2, 2008 | 03:04 PM
Nvisable's Avatar
The latest is Nitto won't warrantee the tires because they aren't the right application for the truck. The only thing that may not be right is the 285 part. Everything else is, weight, e-rated, 10 ply, speed, air pressure, wheel diameter, wheel width...
At this point in my 18 hours of ownership, I will never buy anything Nitto again.
Old Jul 2, 2008 | 03:08 PM
cmac's Avatar
they will probably stiffen up a little after you put some miles on them. Sorry about you luck...
Old Jul 2, 2008 | 03:10 PM
Nvisable's Avatar
I really hope so. It's flat out scary right now.
Old Jul 2, 2008 | 04:16 PM
Ram Daddy's Avatar
I had a set of 37s.....wore them out in 10K miles.
They were SOOO sticky , I couldn`t even powerbrake the truck with them on.
They did ride nice , but pretty pricy to replace that often.
Old Jul 3, 2008 | 09:40 AM
Nvisable's Avatar
Latest update... Nitto still won't warrantee the tires, but the shop spent the day adjusting the air pressures and it's much better now. The truck is completely drivable now.
Old Jul 3, 2008 | 09:43 AM
rip 112's Avatar
did you get the tire road-force balanced? It became necessary to rotate my tires frequently when i had them in the end, but mine did make it to 50k.
Goggleyed
20
Dec 15, 2004 01:36 PM
Strjock81
13
Oct 22, 2004 07:06 PM
KatDiesel
Oct 3, 2004 11:58 PM
Chris Silkowski
Jul 4, 2004 11:47 AM
1tuffdiesel
Jul 1, 2004 10:33 AM
