Stake pockets and Rail protectors - 2007
Old Apr 29, 2007 | 05:51 PM
harwill's Avatar
Unhappy Stake pockets and Rail protectors - 2007
Real happy with my new 2007 2500 - until I bought Mopar bed rail protectors (82209988) and they're too short for my 6'3" bed and the stake hole pockets don't match up either. Then I discovered the stake holes are about 3/16" shorter than my old 2001! And nothing fits them! What gives? Was that a 'New' feature for 2007 or did they screw up before that? The stake pocket holes are gutless so you can't use them. Maybe I shoulda bought a Cab/Chassis . Anybody run into this?
Old Apr 29, 2007 | 06:02 PM
Pooter's Avatar
Make sure you got the right ones, sometimes they mix up PNs.
I ordered some covers from Napa before, went to put them on my truck and they were 2" too long and stake pockets were way off. Turned out it was the right PN ordered, but they sent me some from a shortbed chevy...
Old Apr 29, 2007 | 06:06 PM
annabelle's Avatar
Line-X.......
Old Apr 29, 2007 | 06:21 PM
harwill's Avatar
Gee! Line-X will fix Stupid engineering? Gotta get that. So who makes a stake pocket tie down to fit a 2007?
Old Apr 29, 2007 | 06:43 PM
annabelle's Avatar
At least it will fit! 07 I don't know. Have you tried Cabela's?
Old Apr 29, 2007 | 08:40 PM
harwill's Avatar
Looked in Cabela's online catalog... Hmmm, they have one of those drop-in disappearing rings - but it fits 97-03. And the rubber block type I bought yesterday says, "fits 94 to current Ram" Has the stake pocket been screwed up since 04 and I just bought into it? Come to think of it, I've never bought anything new that didn't have to be remanufactured!
Old Apr 29, 2007 | 08:42 PM
annabelle's Avatar
May be more expensive, but try www.Dodge com
Old Apr 29, 2007 | 10:23 PM
InfernoB's Avatar
I have the aluminum diamond plate rail protectors. They pulled up at the ends so I installed rivets. To fill the holes, I installed my old Ford stainless steel flush mount tie downs. Perfect fit too.(They still say Ford on them, oh well).
Old Apr 30, 2007 | 03:49 AM
Dodgezilla's Avatar
I have the MOPAR units on mine too and the stake pockets line up but the 3M tape doesn't stick for crap!! They look nice.....
Old May 1, 2007 | 11:35 PM
harwill's Avatar
Solved part of the problem: I had Mopar 82209988 rail protectors; A sharp-eyed parts man said wrong ones. Traded for 82209283. Much better! Yes, there is a difference in 1/2 ton and 3/4 ton beds! The stake pocket hole continues to be a travesty. Plan 'A' - drill a 3/8 hole in the bottom of the stake pocket and install a long bolt/nut pointing up. Use a 3/8 rod coupling to tie to the bottom of one of the older expanding rubber block type of inserts. Of course, the rubber block needs to have 1/8 shaved off each side of the long dimension to fit... Naturally, Dodge doesn't make anything to fit the screwed-up stake pocket hole so they don't care!
Old May 5, 2007 | 09:58 PM
DiEseLjunKy's Avatar
Looks like you got the right caps but I was going to say Dee Zee brand diamond plate aluminum caps fit good and the stake holes lined up right.
Old May 7, 2007 | 07:12 AM
ColdCase's Avatar
My Putco Stainless rails fit my 06 shortbed (mega cab) perfectly. The rubber stake pocket inserts have a tendency to loosen, just like most of these types of attachments I've used over the years. I have no experience with rail protectors. I'll look up the Putco part number if you are looking at rails. The way these rails are designed they adjust to some variation in stake pocket distance. The rails are round tubing, so if you need to shorten them a tubing cutter does a nice job I think.
Old May 7, 2007 | 07:38 AM
Peterbilt's Avatar
Try one of your local truck accessory stores. Maybe they have some info.
Pete
SOhappy
Mar 30, 2012 01:06 PM
FirstDodge
Jan 8, 2007 04:29 PM
MikeyB
Apr 23, 2003 11:51 PM
MrBilly
Mar 5, 2003 06:25 AM
Hummin Cummins
Feb 11, 2003 08:28 PM
