RPM Guage Malfunction
No issues, just had to provide my VIN and mileage and they programmed it. Simple swap. I considered installing a used cluster, but was concerned that it may still need to be re-programmed because of the sentry key system on the '06+ trucks.
That sounds like the easiest way for this fix if mine finally dies.
Found this on YouTube...Will be trying today: 2006 Dodge Ram Tachometer fix - YouTube
Should fix the issue....
****ATTENTION****
Learn from my mistake....
DISCONNECT YOUR BATTERIES BEFORE YOU UNPLUG YOUR INSTRUMENT CLUSTER. DO NOT TURN YOUR IGNITION SWITCH ON WITHOUT YOUR INSTRUMENT CLUSTER BEING PLUGGED IN.
I repaired my instrument cluster and while I had it out, I decided to replace scratched/cracked instrument cluster mask/lens. So while I was inside with the laptop, a thunderstorm rolls thru, I ran outside to the truck, windows down (it was hot humid when I tore the dash apart to remove the instrument cluster) I reconnected a battery and put the windows up with the instrument cluster sitting on my kitchen counter.
The above stupidity on my part turned the ECM mother board to toast.
see my related thread here:
https://www.dieseltruckresource.com/...f-t318807.html
<-- me
<-- me
fishin fever
Feb 22, 2004 08:32 PM
17
Jun 22, 2003 07:48 AM
